Unable to reach Octo Print on my PC (connected using LAN) via octopi.local or the IP address of the octopi (grabbed from the router).
The odd part is that I can access OctoPrint instance using my laptop.
When I am trying to ping octopi.local or the IP I am getting 4 Request Timed Out with all 4 packets lost.
This PC was used before to access the exact same instance and the only thing that changed was my residence, I am even using the same ISP router without any settings changed.
Classic L1 stuff reset the router, re imaged octopi (using the PI installer), reinstalled Windows (I really thought this would solve the issue since I can connect from my laptop) without success. Also I was browsing the forum for similar cases and was unable to find any that solved my issue.
My Raspberry PI is connected via WIFI to the network.
Laptop (Win 10) is connected via WIFI to the network.
PC (Win 10) is connected via LAN to the network.
One thing that is different about the setup is that my LAN cable is not connecting directly to the router but to an UTP connection in the wall which is routed through the wall to the router. Although I don't think this should create the issue.
Hopefully someone here knows how to fix this because I would like to avoid sending files from PC to Laptop to OctoPrint ![]()
Thank you in advance and let me know if I need to provide more info.
