I dowloaded and installed Octoprint from octoprint.org here.
I edited the octoprint wpa file using Atom to add my WiFi network.
I can ssh into the octoprint Pi but when I enter the IP address "192.168.1.xxx" nothing happens, well at first I got an "Octorprint is still loading" and then a message to look at the log files.
I removed the USB WebCam and USB Keyboard Dongle and rebooted - same problem.
Octoprint version: octopi-stretch-lite-0.15.1
Here is the output from the log:
GNU nano 2.7.4 File: octoprint.log
2019-01-18 16:04:17,551 - octoprint.server.preemptive_cache - INFO - ... done in 174.76s
2019-01-18 16:07:19,931 - tornado.access - WARNING - 404 GET /80 (127.0.0.1) 45.09ms
2019-01-18 16:15:37,625 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-01-18 16:18:39,406 - octoprint.server - INFO - Shutting down...
2019-01-18 16:18:40,076 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-01-18 16:18:40,082 - octoprint.events - INFO - Event loop shut down
2019-01-18 16:18:40,527 - octoprint.server - INFO - Goodbye!
2019-01-18 16:19:44,295 - octoprint.startup - INFO - ******************************************************************************
2019-01-18 16:19:44,304 - octoprint.startup - INFO - Starting OctoPrint 1.3.8
2019-01-18 16:19:44,308 - octoprint.startup - INFO - ******************************************************************************
2019-01-18 16:19:44,890 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-01-18 16:19:59,537 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 4 hook handlers
2019-01-18 16:20:00,247 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-01-18 16:20:00,497 - octoprint.server - INFO - Intermediary server started
2019-01-18 16:20:00,502 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-01-18 16:20:05,960 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 4 hook handlers
2019-01-18 16:20:06,308 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-01-18 16:20:06,320 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-01-18 16:20:06,614 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-01-18 16:20:22,877 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-01-18 16:20:38,649 - octoprint.util.pip - INFO - Version of pip is 9.0.3
2019-01-18 16:20:38,658 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-01-18 16:20:38,662 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-01-18 16:20:38,680 - octoprint.plugin.core - INFO - Initialized 10 plugin implementation(s)
2019-01-18 16:20:38,738 - octoprint.plugin.core - INFO - 10 plugin(s) registered with the system:
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| OctoPi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/octopi_support
2019-01-18 16:20:38,895 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 388034560
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: B+
| revision: '0013'
| version: 0.15.1
| python:
| pip: 9.0.3
| version: 2.7.13
^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos ^Y Prev Page M-\ First Line M-W WhereIs Next ^^ Mark Text M-} Indent Text M-U Undo
^X Exit ^R Read File ^\ Replace ^U Uncut Text ^T To Spell ^_ Go To Line ^V Next Page M-/ Last Line M-] To Bracket M-^ Copy Text M-{ Unindent TextM-E Redo
