Good morning all, it seems I've broken my Octoprint when doing an update, I can't tell you what version I previously had but it must have been eight months old at least:
I updated a working octoprint installation from the UI, the system is running but no output to browser, after the login prompt I simply get " Connecting to OctoPrint's server..." and a spinning wheel. I can connect to the server using Octopod on my ios device but not by browser. I receive the login request, put in details and get no further. After the update of octoprint I also did a system update but still same issue.
I've tried multiple browsers on multiple systems, I've cleared cache and cleared cookies.
I've tried to run the system in safemode by using: octoprint serve --safe
Yes, system runs, but still cannot access web page, I can still access via octopod, but no camera streaming.
Complete Logs
puk@OctoPi3B:~/OctoPrint/venv $ octoprint serve --safe
2020-10-11 11:03:03,131 - octoprint.startup - INFO - ******************************************************************************
2020-10-11 11:03:03,134 - octoprint.startup - INFO - Starting OctoPrint 1.4.2
2020-10-11 11:03:03,135 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2020-10-11 11:03:03,136 - octoprint.startup - INFO - Reason for safe mode: command line flag
2020-10-11 11:03:03,137 - octoprint.startup - INFO - ******************************************************************************
2020-10-11 11:03:03,848 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2020-10-11 11:03:03,870 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-10-11 11:03:03,871 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 192.168.0.2:53 is working
2020-10-11 11:03:03,873 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-10-11 11:03:04,113 - octoprint.startup - INFO - Blacklist processing done, adding 10 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8)
2020-10-11 11:03:04,147 - octoprint.plugin.core - INFO - Loading plugins from /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins, /home/puk/.octoprint/plugins and installed plugin packages...
2020-10-11 11:03:05,014 - octoprint.plugin.core - INFO - Plugin Anonymous Usage Tracking is disabled.
2020-10-11 11:03:05,785 - octoprint.plugins.octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2020-10-11 11:03:05,805 - octoprint.plugin.core - INFO - Found 23 plugin(s) providing 17 mixin implementations, 32 hook handlers
2020-10-11 11:03:06,071 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-10-11 11:03:06,097 - octoprint.server - INFO - Intermediary server started
2020-10-11 11:03:06,098 - octoprint.plugin.core - INFO - Loading plugins from /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins, /home/puk/.octoprint/plugins and installed plugin packages...
2020-10-11 11:03:06,305 - octoprint.plugin.core - INFO - Found 23 plugin(s) providing 17 mixin implementations, 32 hook handlers
2020-10-11 11:03:06,340 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/puk/.octoprint/uploads...
2020-10-11 11:03:07,123 - octoprint.filemanager.storage - INFO - ... file metadata for /home/puk/.octoprint/uploads initialized successfully.
2020-10-11 11:03:07,128 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-10-11 11:03:07,130 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-10-11 11:03:07,132 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-10-11 11:03:07,133 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-10-11 11:03:07,135 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-10-11 11:03:07,136 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-10-11 11:03:07,139 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-10-11 11:03:07,141 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-10-11 11:03:07,142 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-10-11 11:03:07,145 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-10-11 11:03:07,147 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-10-11 11:03:07,149 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-10-11 11:03:07,151 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-10-11 11:03:07,153 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-10-11 11:03:07,342 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-10-11 11:03:08,397 - octoprint.util.pip - INFO - Using "/usr/bin/python -m pip" as command to invoke pip
2020-10-11 11:03:09,442 - octoprint.util.pip - INFO - Version of pip is 20.1.1
2020-10-11 11:03:09,443 - octoprint.util.pip - INFO - pip installs to /usr/lib/python2.7/dist-packages (writable -> no), --user flag needed -> yes, virtual env -> no
2020-10-11 11:03:09,445 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-10-11 11:03:09,453 - octoprint.plugin.core - INFO - Initialized 17 plugin implementation(s)
2020-10-11 11:03:09,467 - octoprint.plugin.core - INFO - 23 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/announcements
| !Anonymous Usage Tracking (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/backup
| !Bed Visualizer (0.1.15) = /home/puk/.local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| Core Wizard (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/discovery
| Error Tracking (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/errortracking
| File Check (2020.8.7) (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2020.9.23) (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| Logging (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/logging
| Login UI (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/loginui
| !Octolapse (0.4.0) = /home/puk/.local/lib/python2.7/site-packages/octoprint_octolapse
| !OctoPod Plugin (0.2.9) = /home/puk/.local/lib/python2.7/site-packages/octoprint_octopod
| Pi Support Plugin (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
| Software Update (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
| !System Command Editor (0.3.4) = /home/puk/.local/lib/python2.7/site-packages/octoprint_systemcommandeditor
| !TouchUI (0.3.16) = /home/puk/.local/lib/python2.7/site-packages/octoprint_touchui
| Virtual Printer (bundled) = /home/puk/.local/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2020-10-11 11:03:09,483 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 1022779392
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 20.1.1
| version: 2.7.16
2020-10-11 11:03:09,496 - octoprint.server - INFO - Reset webasset folder /home/puk/.octoprint/generated/webassets...
2020-10-11 11:03:09,524 - octoprint.server - INFO - Reset webasset folder /home/puk/.octoprint/generated/.webassets-cache...
2020-10-11 11:03:10,651 - octoprint.server - INFO - Shutting down intermediary server...
2020-10-11 11:03:10,900 - octoprint.server - INFO - Intermediary server shut down
2020-10-11 11:03:10,902 - octoprint.events - INFO - Processing startup event, this is our first event
2020-10-11 11:03:10,904 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2020-10-11 11:03:10,908 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-10-11 11:03:10,909 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2020-10-11 11:03:11,074 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-10-11 11:03:11,714 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-10-11 11:03:12,758 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-10-11 11:03:13,085 - octoprint.server - INFO - Trying to connect to configured serial port /dev/ttyACM0
2020-10-11 11:03:13,141 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-10-11 11:03:13,146 - octoprint.util.comm - INFO - Connecting to port /dev/ttyACM0, baudrate 115200
2020-10-11 11:03:13,154 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-10-11 11:03:13,159 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-10-11 11:03:13,163 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-10-11 11:03:13,178 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-10-11 11:03:13,195 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on OctoPi3B for SSDP
2020-10-11 11:03:13,211 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-10-11 11:03:13,215 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2020-10-11 11:03:13,229 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-10-11 11:03:13,291 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-10-11 11:03:13,501 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-10-11 11:03:13,671 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin bugfix-2.0.x (GitHub)"
2020-10-11 11:03:13,983 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2020-10-11 11:03:14,680 - octoprint.util.pip - INFO - Using "/usr/bin/python -m pip" as command to invoke pip
2020-10-11 11:03:14,681 - octoprint.util.pip - INFO - pip installs to /usr/lib/python2.7/dist-packages (writable -> no), --user flag needed -> yes, virtual env -> no
2020-10-11 11:03:14,681 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-10-11 11:03:14,736 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 22.9GB. That is considered sufficient for updating.
2020-10-11 11:03:15,716 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-10-11 11:03:15,727 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.0.4/'}
2020-10-11 11:03:25,084 - octoprint.server.preemptive_cache - INFO - ... done in 9.36s
2020-10-11 11:04:43,644 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.44
2020-10-11 11:04:44,064 - octoprint.server.util.flask - INFO - Passively logging in user _api from ::ffff:192.168.0.44
2020-10-11 11:04:44,067 - octoprint.access.users - INFO - Logged in user: _api
2020-10-11 11:04:44,146 - octoprint.server.util.sockjs - INFO - User _api logged in on the socket from client ::ffff:192.168.0.44
2020-10-11 11:05:07,841 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.44
OctoPrint version 1.4.2, printer: Ender 3, firmware: Marlin2.0, browser: Chrome, Safari, Opera (plus same on ios devices), operating system: Mac (generally),
Any input would be greatly appreciated, many thanks!
