I am attempting to generate a new API key. However when I click on the button to generate the new API key nothing happens. I need to generate a new API key because I have cloned this install from another RPi to use on an identical printer.
I am running Octopi with v1.3.11.
You should be able to manually delete the value stored in the second computer's ~/.octoprint/config.yaml file and restart OctoPrint.
Maybe you also have to clear the browser cache...
This did the trick. Thanks!
