I get error "No more candidates to test, and no working port/baudrate combination detected." after trying to connect to my Qidi Tech 1 (2018)
3 different USB cables from printer top raspberry pi & increasing timeout intervals. When running the dmesg -w function the printer does show up as a new USB device found see attached picture below. Added the GPX Plugin.
Unknown
octoprint-systeminfo-20250415183515.zip (40.8 KB)
Qidi Tech 1 (2018) to RasberryPi 3+.
