Printer had been working excellently. latest updates all applied. prints successful. Turned printer back on after a day or so and unable to connect to the printer -
No serial port found, are you sure your printer is physically connected and supported? Try [refreshing](javascript:void(0)) and if that doesn't help please see the FAQ.
Confirmed cables are functional for data and USB port works on Pi.
pi@octopi:~ $ dmesg | tail -n 20
[ 7973.948410] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 7974.090594] usb 1-1.3: New USB device found, idVendor=13fe, idProduct=5100, bcdDevice= 1.00
[ 7974.090647] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7974.090663] usb 1-1.3: Product:
[ 7974.090678] usb 1-1.3: Manufacturer:
[ 7974.090692] usb 1-1.3: SerialNumber: 07032AEDB40AB738
[ 7974.092746] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 7974.099009] scsi host0: usb-storage 1-1.3:1.0
[ 7974.161067] usbcore: registered new interface driver uas
[ 7975.332747] scsi 0:0:0:0: Direct-Access PMAP PQ: 0 ANSI: 4
[ 7975.351964] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 7979.639168] sd 0:0:0:0: [sda] 60532992 512-byte logical blocks: (31.0 GB/28.9 GiB)
[ 7979.639477] sd 0:0:0:0: [sda] Write Protect is off
[ 7979.639497] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 7979.639795] sd 0:0:0:0: [sda] No Caching mode page found
[ 7979.639814] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 7980.091177] sda: sda1
[ 7980.094948] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 8361.242059] usb 1-1.3: USB disconnect, device number 4
Following this the I tried plugging in the printer again and no further changes or connections with Printer.
Yes no change. Octopi not connecting
octoprint-systeminfo-20230102003352.zip (25.3 KB)
OctoPrint version : 1.8.6
OctoPi version : 0.18.0
Board - Creality3D RAMPS
Baud: 250000
Protocol : 1.0
PSU : Generic
FirmWare - Marlin
2.0.5_NIC
2020-04-10
