This is what i get when i use dmesg.
pi@octopi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.79-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1373 SMP Mon Nov 23 13:27:40 GMT 2020
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 491520
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 294912 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
[ 0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 489216
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:720x576M@50,margin_left=32,margin_right=32,margin_top=32,margin_bottom=32 smsc95xx.macaddr=DC:A6:32:F7:22:F6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=e76edab1-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x19400000-0x1d400000] (64MB)
[ 0.000000] Memory: 1595172K/1966080K available (10240K kernel code, 739K rwdata, 2816K rodata, 2048K init, 854K bss, 108764K reserved, 262144K cma-reserved, 1179648K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 31111 entries in 61 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x344/0x518 with crng_init=0
[ 0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000029] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000108] bcm2835: system timer (irq = 17)
[ 0.000755] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000775] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000796] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000812] Switching to timer-based delay loop, resolution 18ns
[ 0.001050] Console: colour dummy device 80x30
[ 0.001556] printk: console [tty1] enabled
[ 0.001621] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001664] pid_max: default: 32768 minimum: 301
[ 0.001824] LSM: Security Framework initializing
[ 0.002028] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002069] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003400] Disabling memory control group subsystem
[ 0.003538] CPU: Testing write buffer coherency: ok
[ 0.004039] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004954] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005173] rcu: Hierarchical SRCU implementation.
[ 0.005857] smp: Bringing up secondary CPUs ...
[ 0.007023] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008317] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009548] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009706] smp: Brought up 1 node, 4 CPUs
[ 0.009778] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.009804] CPU: All CPU(s) started in HYP mode.
[ 0.009829] CPU: Virtualization extensions available.
[ 0.010727] devtmpfs: initialized
[ 0.024297] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.024583] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.024634] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.031431] pinctrl core: initialized pinctrl subsystem
[ 0.032436] NET: Registered protocol family 16
[ 0.036008] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.036611] audit: initializing netlink subsys (disabled)
[ 0.036871] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.037911] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.037947] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.038275] Serial: AMBA PL011 UART driver
[ 0.041976] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.060825] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-11-25 17:11, variant start_x
[ 0.070842] raspberrypi-firmware soc:firmware: Firmware hash is 2e6292a5304b95ecfd700fc5ab2b793402056332
[ 0.125671] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.130724] vgaarb: loaded
[ 0.131234] SCSI subsystem initialized
[ 0.131457] usbcore: registered new interface driver usbfs
[ 0.131540] usbcore: registered new interface driver hub
[ 0.131675] usbcore: registered new device driver usb
[ 0.132017] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
[ 0.133773] clocksource: Switched to clocksource arch_sys_counter
[ 0.892603] VFS: Disk quotas dquot_6.6.0
[ 0.892723] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.892914] FS-Cache: Loaded
[ 0.893130] CacheFiles: Loaded
[ 0.894065] simple-framebuffer 3ea7f000.framebuffer: framebuffer at 0x3ea7f000, 0x148000 bytes, mapped to 0x(ptrval)
[ 0.894108] simple-framebuffer 3ea7f000.framebuffer: format=a8r8g8b8, mode=656x512x32, linelength=2624
[ 0.896209] Console: switching to colour frame buffer device 82x32
[ 0.898028] simple-framebuffer 3ea7f000.framebuffer: fb0: simplefb registered!
[ 0.908380] thermal_sys: Registered thermal governor 'step_wise'
[ 0.908732] NET: Registered protocol family 2
[ 0.911768] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.914125] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.916461] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.917696] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.918990] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.920188] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.921644] NET: Registered protocol family 1
[ 0.923539] RPC: Registered named UNIX socket transport module.
[ 0.924800] RPC: Registered udp transport module.
[ 0.926019] RPC: Registered tcp transport module.
[ 0.927200] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.928379] PCI: CLS 0 bytes, default 64
[ 0.931369] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.935904] Initialise system trusted keyrings
[ 0.937333] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.949295] FS-Cache: Netfs 'nfs' registered for caching
[ 0.951203] NFS: Registering the id_resolver key type
[ 0.952397] Key type id_resolver registered
[ 0.953541] Key type id_legacy registered
[ 0.954704] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.956920] Key type asymmetric registered
[ 0.958033] Asymmetric key parser 'x509' registered
[ 0.959302] bounce: pool size: 64 pages
[ 0.960419] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.962756] io scheduler mq-deadline registered
[ 0.963873] io scheduler kyber registered
[ 0.968795] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.969851] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.971903] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
[ 0.974051] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x007fffffff -> 0x0000000000
[ 1.573804] brcm-pcie fd500000.pcie: link down
[ 1.579247] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.583463] iproc-rng200 fe104000.rng: hwrng registered
[ 1.584962] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.587819] vc-sm: Videocore shared memory driver
[ 1.589519] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.603792] brd: module loaded
[ 1.617227] loop: module loaded
[ 1.619715] Loading iSCSI transport class v2.0-870.
[ 1.622832] libphy: Fixed MDIO Bus: probed
[ 1.624601] bcmgenet fd580000.ethernet: failed to get enet clock
[ 1.625716] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.626820] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 1.627922] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 1.628988] bcmgenet: Skipping UMAC reset
[ 1.643813] libphy: bcmgenet MII bus: probed
[ 1.723886] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.725969] usbcore: registered new interface driver r8152
[ 1.727067] usbcore: registered new interface driver lan78xx
[ 1.728138] usbcore: registered new interface driver smsc95xx
[ 1.729655] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.730920] dwc_otg: FIQ enabled
[ 1.730932] dwc_otg: NAK holdoff enabled
[ 1.730945] dwc_otg: FIQ split-transaction FSM enabled
[ 1.730961] Module dwc_common_port init
[ 1.731381] usbcore: registered new interface driver uas
[ 1.732388] usbcore: registered new interface driver usb-storage
[ 1.733497] mousedev: PS/2 mouse device common for all mice
[ 1.736407] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.740791] sdhci: Secure Digital Host Controller Interface driver
[ 1.741711] sdhci: Copyright(c) Pierre Ossman
[ 1.743222] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.744750] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.749433] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.750622] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.751683] usbcore: registered new interface driver usbhid
[ 1.752554] usbhid: USB HID core driver
[ 1.754474] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 1.756906] [vc_sm_connected_init]: start
[ 1.763259] [vc_sm_connected_init]: end - returning 0
[ 1.766380] Initializing XFRM netlink socket
[ 1.767284] NET: Registered protocol family 17
[ 1.768282] Key type dns_resolver registered
[ 1.769483] Registering SWP/SWPB emulation handler
[ 1.770703] registered taskstats version 1
[ 1.771600] Loading compiled-in X.509 certificates
[ 1.773008] Key type ._fscrypt registered
[ 1.773934] Key type .fscrypt registered
[ 1.785310] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.786293] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[ 1.794719] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 30, base_baud = 62500000) is a 16550
[ 1.797412] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.799431] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.800474] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.850573] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.853264] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.855948] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.859871] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.862443] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.867012] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.871694] of_cfs_init
[ 1.872822] of_cfs_init: OK
[ 1.874609] Waiting for root device PARTUUID=e76edab1-02...
[ 1.912857] random: fast init done
[ 1.943573] mmc1: new high speed SDIO card at address 0001
[ 1.978853] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.980634] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
[ 1.983523] mmcblk0: p1 p2
[ 2.000941] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.001908] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.141443] EXT4-fs (mmcblk0p2): recovery complete
[ 2.144386] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.146311] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.155164] devtmpfs: mounted
[ 2.164612] Freeing unused kernel memory: 2048K
[ 2.165818] Run /sbin/init as init process
[ 2.558788] systemd[1]: System time before build time, advancing clock.
[ 2.656224] NET: Registered protocol family 10
[ 2.658423] Segment Routing with IPv6
[ 2.689410] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.693676] systemd[1]: Detected architecture arm.
[ 2.762015] systemd[1]: Set hostname to <octopi>.
[ 3.444676] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.456072] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.457845] systemd[1]: Listening on Syslog Socket.
[ 3.460941] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.462381] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.468320] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.472017] systemd[1]: Listening on Journal Socket.
[ 3.475581] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.485437] systemd[1]: Starting Load Kernel Modules...
[ 3.488729] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 4.066952] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.177424] systemd-journald[116]: Received request to flush runtime journal from PID 1
[ 4.681721] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.691984] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.701735] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.702236] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.743228] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.745377] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.745404] [vc_sm_connected_init]: start
[ 4.746878] [vc_sm_connected_init]: installed successfully
[ 4.749154] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.755185] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 4.756384] mc: Linux media interface: v0.10
[ 4.785096] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 4.789392] videodev: Linux video capture interface: v2.00
[ 4.820587] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.826974] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.861068] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.874275] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.040162] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.091806] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.151445] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.156727] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.156749] checking generic (3ea7f000 148000) vs hw (0 ffffffffffffffff)
[ 5.156765] fb0: switching to vc4drmfb from simple
[ 5.158059] Console: switching to colour dummy device 80x30
[ 5.158299] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.158313] [drm] No driver support for vblank timestamp query.
[ 5.158326] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.161073] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.234132] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.249787] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.251618] usbcore: registered new interface driver brcmfmac
[ 5.274563] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.429273] Console: switching to colour frame buffer device 90x36
[ 5.451414] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 5.469686] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.469911] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.469968] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.470053] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.470389] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.470713] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.470738] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.470760] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.470781] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.470801] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.471006] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.487209] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.487291] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.491071] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.491150] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.517821] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.526636] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 7.536916] uart-pl011 fe201000.serial: no DMA platform data
[ 7.619999] random: crng init done
[ 7.620015] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.668921] 8021q: 802.1Q VLAN Support v1.8
[ 7.943858] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.012313] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.268889] bcmgenet: Skipping UMAC reset
[ 8.270645] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 8.270842] bcmgenet fd580000.ethernet eth0: Link is Down
[ 13.455490] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 14.375792] Bluetooth: Core ver 2.22
[ 14.375866] NET: Registered protocol family 31
[ 14.375878] Bluetooth: HCI device and connection manager initialized
[ 14.375901] Bluetooth: HCI socket layer initialized
[ 14.375919] Bluetooth: L2CAP socket layer initialized
[ 14.375947] Bluetooth: SCO socket layer initialized
[ 14.383487] Bluetooth: HCI UART driver ver 2.3
[ 14.383504] Bluetooth: HCI UART protocol H4 registered
[ 14.383576] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.383929] Bluetooth: HCI UART protocol Broadcom registered
[ 14.570761] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.570768] Bluetooth: BNEP filters: protocol multicast
[ 14.570781] Bluetooth: BNEP socket layer initialized
[ 15.372773] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
lsusb returns nothing. I tried 2 different usb dongles for wireless mouse.
