Unable to connect to my pi over the wifi
I am unable to connect to my rasp pi,following is what I did.
I installed the latest version of octopi (0.17.0) by using the etcher software. I added my ssid and password and un commented those lines. I did all the editing with notepad ++. and i am using a 4 GB SD card.
I have rasp pi 3 model B
Using a samsung charger to power it up wich has 5v 2A
Using windows OS on my comp
Hello @hussain
You may connect the Pi to a HDMI monitor or TV, you get the network information at the end.
You also may try to connect via LAN cable.
And in addition:
A charger is not a power supply.
Try to get a power supply with 5V / 2.5A
Thanks for your reply,
Do i need to comment out the lines that contain my ssid and password if I connect by lan cable ? any other modifications required ?
After powering up the pi I was not able to find it listed in my routers network....
Hey I managed to connect to the octopi , thank you for helping. I think I just waited for like 5 mins for the octopi to load and then it was fine !
Thank you !!
Great! Could you please do this: PSA: Please mark the solutions to your topics as such
Just a note for others, on the first boot (if you were seeing this on a local monitor) the Pi expands the ext4 partition and then reboots. So it may take longer to show up as available this first time.
