Unable to connect to octoprint
I'm using the latest version of octopi with the new camera stack. I've not had issues until about a week ago. Suddenly I was unable to connect.
Unplugging and plugging the power had no effect. I checked my router, and the octopi instance does appear in there. I've tried to SSH into both octoprint.local and the ip using windows powershell, but in both cases the connection timed out.
Since I cannot access octoprint I'm unable to enable safe mode.
Since I cannot access octoprint I'm unable to get the info bundle.
Additional information
Sorry for the lack of info, but I sadly don't know how to get more.
Try connecting an HDMI display (a TV screen is even fine for debugging) and see if there is any output, or error messages. If it’s connected to the network, it should tell you & report its IP address.
If you have a spare SD card, it may be worth a fresh install to check it’s not corrupted.
if you can i suggest to use the stable version of octoprint and what version of the imager are you using? what raspberry pi do you have, is it connected via Wlan or LAN?, have you rewritten the image onto the sd card?
Same as on the other thread.
yes i didnt see my bad my bad. will not do it again.
