Unable to connect via browsers to octopi.local or via IP address
This is all that is in the octoprint.log file (error wise)
2023-06-16 09:29:42,134 - octoprint.server.util.flask.fix_webassets_filtertool - ERROR - Got an exception while trying to apply filter, ignoring file
File "/home/frank/oprint/lib/python3.9/site-packages/octoprint/server/util/flask.py", line 183, in fixed_wrap_cache
content = func().getvalue()
File "/home/frank/oprint/lib/python3.9/site-packages/webassets/merge.py", line 250, in func
data = StringIO(hunk.data())
File "/home/frank/oprint/lib/python3.9/site-packages/webassets/merge.py", line 80, in data
return f.read()
File "/usr/lib/python3.9/codecs.py", line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x80 in position 54610: invalid start byte
2023-06-16 09:29:42,136 - octoprint.server.util.flask.fix_webassets_filtertool - ERROR - Got an exception while trying to apply filter, ignoring file
return f.read()
Rebooted multiple times, can connect via SSH to pi and can ping octopi.local (connection refused error) updated via sudo apt update, sudo apt upgrade to latest version (as of date of posting).
Define 'Safe Mode'
See above
Unable to connect via browser!!!!! neither sudo octoprint systeminfo nor octoprint systeminfo will run on OctoPi at commandline
OctoPrint version 1.9.0, OctoPi version 1.0.0, printer Prusa MK3S+, firmware Latest Prusa Firmware, browser Multiple chromium based versions as well as Firefox, operating system Windows 11 22H2
Note that this worked previously (3 weeks prior) have not used since and has been powered off.
Hello @fnketterman !
Definition: Blue words are links.
