All guides I can find tell me to flash my SD card, mount the drive, and make simple edits to an octopi-wpa-supplicant.txt file in the drive's new boot directory. But there is no file to edit.
Flash the drive with Etcher, flash the drive again with a dd command, tried downloading a release directly from github in case the octoprint website had a bad link. It really isn't there; the closest related thing is, the symlink in etc/wpa_supplicant which is pointing to /boot/octopi-wpa-supplicant.txt.
n/a
Additional information about your network
n/a
