C920 & C270
I cannot get both these cameras to stream in octoprint, i have tried to check the Webcamd log but cannot see if anything is wrong and would appreciate if someone could cast an eye over it!
I made a working copy of octoprint on a Pi4b, i then created a fresh install exactly the same way using Raspberry Pi imager 3 with a clean install of Octopi as per previous SD card.
I edited the various files as per the prevoius SD card so they should be identical.
When i run the 2nd copy i cannot get both streams to display. I have been over and over the setup files and they look identical to me. Printed and attached a copy of the Webcamd log.
octoprint-systeminfo-20230424211058.zip (11.8 KB)
octoprint 1.8.7 python 3.9.2 octopi 1.0.0
Webcamd Log:
kdhdd@raspberrypi:/var/log $ cat webcamd.log
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly set USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video2
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video3
/dev/video31
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
Camera model 046d:0825 is known to not work with -f parameter, stripping it out
<13>Sep 22 01:24:22 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -d /dev/video0
MJPG Streamer Version.: 2.0
i: Frames Per Second.: -1
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Done bringing up all configured video devices
i: select() timeout
i: cleaning up resources allocated by input thread
/root/bin/webcamd: line 103: kill: (671) - No such process
Goodbye...
camera: auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video2
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video3
/dev/video31
<13>Sep 22 01:24:39 root: Starting USB webcam
Goodbye...
camera: usb
usb options: -r 640x480 -f 10 -d /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_EA8C33AF-video-index0
Explicitly set USB device: /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_EA8C33AF-video-index0
cfg_file: /boot/octopi.conf.d/webcam2.txt
camera: usb
usb options: -r 640x480 -f 10 -d/dev/v4l/by-id/usb-046d_0825_BE641540-video-index0
http options: -w ./www-octopi -n -p 8081
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video2
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video3
/dev/video31
config file='/boot/octopi.txt':USB device was set in options and found in devices, starting MJPG-streamer with the configured USB video device: /dev/video2
<13>Apr 24 20:45:09 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video2
i: Using V4L2 device.: /dev/video2
i: Frames Per Second.: 10
config file='/boot/octopi.conf.d/webcam2.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
<13>Apr 24 20:45:10 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -p 8081 -i input_uvc.so -r 640x480 -d/dev/v4l/by-id/usb-046d_0825_BE641540-video-index0 -d /dev/video0
UVC webcam grabber: unrecognized option '-d/dev/v4l/by-id/usb-046d_0825_BE641540-video-index0'
Help for input plugin..: UVC webcam grabber
The following parameters can be passed to this plugin:
[-d | --device ].......: video device to open (your camera)
[-r | --resolution ]...: the resolution of the video device,
can be one of the following strings:
QQVGA QCIF CGA QVGA CIF PAL
VGA SVGA XGA HD SXGA UXGA
FHD
or a custom value like the following
example: 640x480
[-f | --fps ]..........: frames per second
(camera may coerce to different value)
[-q | --quality ] .....: set quality of JPEG encoding
[-m | --minimum_size ].: drop frames smaller then this limit, useful
if the webcam produces small-sized garbage frames
may happen under low light conditions
[-e | --every_frame ]..: drop all frames except numbered
[-n | --no_dynctrl ]...: do not initalize dynctrls of Linux-UVC driver
[-l | --led ]..........: switch the LED "on", "off", let it "blink" or leave
it up to the driver using the value "auto"
[-t | --tvnorm ] ......: set TV-Norm pal, ntsc or secam
[-u | --uyvy ] ........: Use UYVY format, default: MJPEG (uses more cpu power)
[-y | --yuv ] ........: Use YUV format, default: MJPEG (uses more cpu power)
[-fourcc ] ............: Use FOURCC codec 'argopt',
currently supported codecs are: RGB24, RGBP
[-timestamp ]..........: Populate frame timestamp with system time
[-softfps] ............: Drop frames to try and achieve this fps
set your camera to its maximum fps to avoid stuttering
[-timeout] ............: Timeout for device querying (seconds)
[-dv_timings] .........: Enable DV timings queriyng and events processing
Optional parameters (may not be supported by all cameras):
[-br ].................: Set image brightness (auto or integer)
[-co ].................: Set image contrast (integer)
[-sh ].................: Set image sharpness (integer)
[-sa ].................: Set image saturation (integer)
[-cb ].................: Set color balance (auto or integer)
[-wb ].................: Set white balance (auto or integer)
[-ex ].................: Set exposure (auto, shutter-priority, aperature-priority, or integer)
[-bk ].................: Set backlight compensation (integer)
[-rot ]................: Set image rotation (0-359)
[-hf ].................: Set horizontal flip (true/false)
[-vf ].................: Set vertical flip (true/false)
[-pl ].................: Set power line filter (disabled, 50hz, 60hz, auto)
[-gain ]...............: Set gain (auto or integer)
[-cagc ]...............: Set chroma gain control (auto or integer)
input_init() return value signals to exit
