Starting tonight, OctoPrint stopped accepting my login credentials. I load up the local IP of the printer and am greeted with the typical login screen that also says "Site says: octoprint." But the user and pass won't take.
I then logged into the Pi via SSH with no problem. Per many sources of the same instructions, I deleted .octoprint/users.yaml and edited config.yaml so that firstRun (under server) was set to true. I then restarted the service with 'sudo service octoprint restart.'
But when I returned to the browser and tried to reload the page, I got the same login prompt. I've tried different browsers and devices, all with the same login prompt popping up.
One set of instructions said that I should also set accessControl > enabled to true, but I actually didn't have an enabled line at all. I tried adding that line with both true and false with no difference in the result. The only thing listed under accessControl is a salt string.
Finally, I also tried one user's suggestion (last post here: https://github.com/foosel/OctoPrint/issues/1063) where I used the salt from config.yaml to try and generate a new password hash with sha512, but no luck. I'm not too sure I did that right, anyway, tbh. The instructions seemed to indicate that I should put my plaintext password in front of the salt string and run that through sha512sum... is that right?
Anyway, this is with Octoprint 0.14.0. Klipper is also loaded, but I can't imagine that has anything to do with this.
My hat's off to anyone who can get me out of this mess. I'd really rather not start over from scratch
