Following what appears to be a successful update to 1.3.9 from 1.3.8 on an octopi. The octoprint service no longer starts. Looking at the logs the error appears to be:
[B2018-08-05 13:33:09,710 - octoprint.startup - INFO - ******************************************************************************
2018-08-05 13:33:09,712 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-08-05 13:33:09,714 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2018-08-05 13:33:09,714 - octoprint.startup - INFO - ******************************************************************************
2018-08-05 13:33:10,815 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-08-05 13:33:11,003 - octoprint.startup - INFO - Blacklist processing done
2018-08-05 13:33:11,039 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-08-05 13:33:11,401 - octoprint.plugin.core - ERROR - Error loading plugin softwareupdate
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 847, in _import_plugin
instance = imp.load_module(key, f, filename, description)
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 26, in <module>
from octoprint.server.util.flask import restricted_access, with_revalidation_checking, check_etag
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/__init__.py", line 9, in <module>
from octoprint.vendor.sockjs.tornado import SockJSRouter
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/__init__.py", line 3, in <module>
from .router import SockJSRouter
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/router.py", line 11, in <module>
from octoprint.vendor.sockjs.tornado import transports, session, sessioncontainer, static, stats, proto
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/transports/__init__.py", line 3, in <module>
import octoprint.vendor.sockjs.tornado.transports.pollingbase
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/transports/pollingbase.py", line 9, in <module>
from octoprint.vendor.sockjs.tornado import basehandler
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/basehandler.py", line 13, in <module>
from tornado.web import asynchronous, RequestHandler
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/web.py", line 85, in <module>
from tornado import gen
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/gen.py", line 99, in <module>
from singledispatch import singledispatch # backport
ImportError: cannot import name singledispatch
2018-08-05 13:33:11,439 - octoprint.plugin.core - ERROR - Error loading plugin action_command_prompt
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt/__init__.py", line 9, in <module>
from octoprint.server import user_permission
2018-08-05 13:33:11,463 - octoprint.plugin.core - ERROR - Error loading plugin logging
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging/__init__.py", line 10, in <module>
from octoprint.server import NO_CONTENT, admin_permission
2018-08-05 13:33:11,533 - octoprint.plugin.core - ERROR - Error loading plugin pluginmanager
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 14, in <module>
2018-08-05 13:33:11,704 - octoprint.plugin.core - ERROR - Error loading plugin announcements
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements/__init__.py", line 23, in <module>
from octoprint.server import admin_permission
2018-08-05 13:33:11,780 - octoprint.plugin.core - ERROR - Error loading plugin printer_safety_check
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check/__init__.py", line 10, in <module>
2018-08-05 13:33:12,412 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 5 mixin implementations, 1 hook handlers
2018-08-05 13:33:12,518 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/oprint/bin/octoprint", line 11, in <module>
sys.exit(main())
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/__init__.py", line 599, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 716, in __call__
return self.main(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 696, in main
rv = self.invoke(ctx)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 1037, in invoke
return Command.invoke(self, ctx)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 889, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 534, in invoke
return callback(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/decorators.py", line 17, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/__init__.py", line 175, in octo
ctx.invoke(serve_command, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 188, in serve_command
ignore_blacklist)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 97, in run_server
from octoprint.server import Server
I have tried to start it in safe mode, I reverted back to 1.3.8 and it worked fine but upgrading again caused the problem,
Any help would be wonderful
Octopi version
OctoPrint version : 1.3.9
OctoPi version : 0.15.1
