octoprint.log
2020-04-25 15:53:09,485 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-25 15:53:09,510 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2020-04-25 15:53:09,511 - octoprint.server - INFO - OctoPrint 1.4.0
2020-04-25 15:53:09,514 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
2020-04-25 15:53:09,527 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-04-25 15:53:09,528 - octoprint.server - INFO - ------------------------------------------------------------------------------
2020-04-25 15:53:20,305 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'plugins': u''}
2020-04-25 15:53:21,118 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 22}
2020-04-25 15:53:25,147 - octoprint.server.preemptive_cache - INFO - ... done in 18.93s
2020-04-25 15:53:25,149 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.2.21:4080/'}
2020-04-25 15:53:27,819 - octoprint.server.preemptive_cache - INFO - ... done in 2.67s
2020-04-25 15:53:27,820 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.2.29:4080/'}
2020-04-25 15:53:30,501 - octoprint.server.preemptive_cache - INFO - ... done in 2.68s
2020-04-25 15:53:30,502 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.2.30:4080/'}
2020-04-25 15:53:33,280 - octoprint.server.preemptive_cache - INFO - ... done in 2.78s
2020-04-25 15:55:26,292 - octoprint.filemanager.analysis - INFO - Analysis of entry local:SLCValley_test.gcode finished, needed 152.94s
2020-04-25 15:55:44,236 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.16
2020-04-25 15:55:48,302 - octoprint.access.users - INFO - Logged in user: MPCNC
2020-04-25 15:55:48,308 - octoprint.server.api - INFO - Actively logging in user MPCNC from ::ffff:192.168.2.16
2020-04-25 15:55:48,381 - octoprint.server.util.flask - INFO - Passively logging in user MPCNC from ::ffff:192.168.2.16
2020-04-25 15:55:48,382 - octoprint.access.users - INFO - Logged in user: MPCNC
2020-04-25 15:55:48,423 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'query_string': u'l10n=en', 'path': u'/', u'_count': 1, u'_timestamp': 1587826548.423734, 'base_url': u'http://192.168.2.12:4080/'}
2020-04-25 15:55:50,577 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.16
2020-04-25 15:55:52,351 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.16
2020-04-25 15:55:52,485 - octoprint.server.util.flask - INFO - Passively logging in user MPCNC from ::ffff:192.168.2.16
2020-04-25 15:55:52,486 - octoprint.access.users - INFO - Logged in user: MPCNC
2020-04-25 15:55:53,983 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.74s
2020-04-25 15:55:55,203 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.92s
2020-04-25 15:55:56,995 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.77s
2020-04-25 15:55:57,988 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.9s
2020-04-25 15:55:58,948 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.82s
2020-04-25 15:56:00,418 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2020-04-25 15:56:02,371 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2020-04-25 15:56:03,380 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-04-25 15:56:03,461 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 69.58ms
2020-04-25 15:56:15,000 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 57.99ms
2020-04-25 15:56:16,449 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 32.27ms
2020-04-25 15:56:27,051 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 79.44ms
2020-04-25 15:56:28,614 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 48.49ms
2020-04-25 15:56:41,851 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 33.71ms
2020-04-25 15:57:02,775 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 33.52ms
2020-04-25 15:57:12,653 - tornado.access - ERROR - 500 GET /api/files?recursive=true&force=true (::ffff:192.168.2.16) 72.88ms
2020-04-25 15:57:30,894 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 82.07ms
2020-04-25 15:58:38,322 - octoprint.startup - INFO - ******************************************************************************
2020-04-25 15:58:38,325 - octoprint.startup - INFO - Starting OctoPrint 1.4.0
2020-04-25 15:58:38,325 - octoprint.startup - INFO - ******************************************************************************
2020-04-25 15:58:39,195 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2020-04-25 15:58:39,347 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-04-25 15:58:41,473 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 27 hook handlers
2020-04-25 15:58:41,741 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-04-25 15:58:41,794 - octoprint.server - INFO - Intermediary server started
2020-04-25 15:58:41,795 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-04-25 15:58:41,942 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 27 hook handlers
2020-04-25 15:58:41,982 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-04-25 15:58:41,990 - octoprint.filemanager.storage - INFO - Deleted 1 stale or invalid entries from metadata for path /home/pi/.octoprint/uploads
2020-04-25 15:58:43,311 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-04-25 15:58:43,317 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-04-25 15:58:43,318 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-04-25 15:58:43,320 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-04-25 15:58:43,322 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-04-25 15:58:43,323 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-04-25 15:58:43,324 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-04-25 15:58:43,327 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-04-25 15:58:43,329 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-04-25 15:58:43,331 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-04-25 15:58:43,333 - octoprint.server - INFO - Added new permission from plugin printer_safety_check: PLUGIN_PRINTER_SAFETY_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_printer_safety_check_display')")
2020-04-25 15:58:43,335 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-04-25 15:58:43,336 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-04-25 15:58:43,408 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-04-25 15:58:44,791 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-04-25 15:58:45,988 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-04-25 15:58:45,991 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-04-25 15:58:45,991 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-04-25 15:58:45,998 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2020-04-25 15:58:46,012 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
2020-04-25 15:58:46,030 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.3.1
| version: 2.7.16
2020-04-25 15:58:46,072 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-04-25 15:58:46,095 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-04-25 15:58:47,130 - octoprint.server - INFO - Shutting down intermediary server...
2020-04-25 15:58:47,456 - octoprint.server - INFO - Intermediary server shut down
2020-04-25 15:58:47,459 - octoprint.events - INFO - Processing startup event, this is our first event
2020-04-25 15:58:47,461 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2020-04-25 15:58:47,463 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-04-25 15:58:47,464 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2020-04-25 15:58:47,535 - octoprint.filemanager.analysis - INFO - Starting analysis of local:SLCValley_test.gcode
2020-04-25 15:58:47,538 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.01 --throttle-lines=100 /home/pi/.octoprint/uploads/SLCValley_test.gcode
2020-04-25 15:58:47,594 - octoprint.filemanager - INFO - Added 2 items from storage type "local" to analysis queue
2020-04-25 15:58:47,652 - octoprint.server - INFO - Trying to connect to configured serial port /dev/ttyACM0
2020-04-25 15:58:47,714 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-04-25 15:58:47,724 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2020-04-25 15:58:47,737 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2020-04-25 15:58:47,732 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-04-25 15:58:47,744 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on v1pi' for _http._tcp
2020-04-25 15:58:47,748 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-04-25 15:58:47,765 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on v1pi' for _octoprint._tcp
2020-04-25 15:58:47,783 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on v1pi for SSDP
2020-04-25 15:58:47,832 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-04-25 15:58:47,885 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-04-25 15:58:48,928 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-04-25 15:58:49,352 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-04-25 15:58:49,354 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-04-25 15:58:49,374 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-04-25 15:58:49,446 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-04-25 15:58:53,576 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-04-25 15:58:56,237 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 15:58:56,824 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-04-25 15:58:56,830 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2020-04-25 15:58:56,842 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-04-25 15:58:56,873 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 414 bugfix-2.0.x (GitHub)"
2020-04-25 15:58:56,892 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2020-04-25 15:59:06,247 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 15:59:13,741 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 55723), not sending a M-SEARCH reply
2020-04-25 15:59:13,747 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 55723), not sending a M-SEARCH reply
2020-04-25 15:59:15,742 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 51043), not sending a M-SEARCH reply
2020-04-25 15:59:15,746 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 51043), not sending a M-SEARCH reply
2020-04-25 15:59:16,233 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 15:59:17,588 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-04-25 15:59:17,589 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-04-25 15:59:17,609 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-04-25 15:59:17,761 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 51491), not sending a M-SEARCH reply
2020-04-25 15:59:17,765 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 51491), not sending a M-SEARCH reply
2020-04-25 15:59:17,797 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.2.12:4080/'}
2020-04-25 15:59:26,272 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 15:59:35,233 - octoprint.server.preemptive_cache - INFO - ... done in 17.44s
2020-04-25 15:59:36,240 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 15:59:46,237 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 15:59:56,244 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 16:00:06,259 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 16:00:13,778 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 55910), not sending a M-SEARCH reply
2020-04-25 16:00:13,782 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 55910), not sending a M-SEARCH reply
2020-04-25 16:00:15,743 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 37387), not sending a M-SEARCH reply
2020-04-25 16:00:15,747 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 37387), not sending a M-SEARCH reply
2020-04-25 16:00:16,236 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 16:00:17,774 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 56202), not sending a M-SEARCH reply
2020-04-25 16:00:17,781 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 56202), not sending a M-SEARCH reply
2020-04-25 16:00:26,262 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 16:00:27,503 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.16
2020-04-25 16:00:32,204 - octoprint.access.users - INFO - Logged in user: MPCNC
2020-04-25 16:00:32,206 - octoprint.server.api - INFO - Actively logging in user MPCNC from ::ffff:192.168.2.16
2020-04-25 16:00:32,267 - octoprint.server.util.flask - INFO - Passively logging in user MPCNC from ::ffff:192.168.2.16
2020-04-25 16:00:32,268 - octoprint.access.users - INFO - Logged in user: MPCNC
2020-04-25 16:00:32,295 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'query_string': u'l10n=en', 'path': u'/', u'_count': 1, u'_timestamp': 1587826832.295436, 'base_url': u'http://169.254.55.97:4080/'}
2020-04-25 16:00:35,005 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.16
2020-04-25 16:00:36,348 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.2.15', 41162), not sending a M-SEARCH reply
2020-04-25 16:00:37,533 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.16
2020-04-25 16:00:37,616 - octoprint.server.util.flask - INFO - Passively logging in user MPCNC from ::ffff:192.168.2.16
2020-04-25 16:00:37,617 - octoprint.access.users - INFO - Logged in user: MPCNC
2020-04-25 16:00:43,328 - octoprint.server.util.sockjs - INFO - User MPCNC logged in on the socket from client ::ffff:192.168.2.16
2020-04-25 16:01:30,150 - octoprint.filemanager.analysis - INFO - Analysis of entry local:SLCValley_test.gcode finished, needed 153.06s
2020-04-25 16:01:31,168 - octoprint.filemanager.analysis - INFO - Starting analysis of local:SLCValley_1_1.gcode
2020-04-25 16:01:31,173 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.01 --throttle-lines=100 /home/pi/.octoprint/uploads/SLCValley_1_1.gcode
2020-04-25 16:02:31,053 - octoprint.server.util.flask - INFO - Passively logging in user MPCNC from ::ffff:192.168.2.16
2020-04-25 16:02:31,055 - octoprint.access.users - INFO - Logged in user: MPCNC
2020-04-25 16:02:33,712 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.16
2020-04-25 16:02:33,803 - octoprint.server.util.flask - INFO - Passively logging in user MPCNC from ::ffff:192.168.2.16
2020-04-25 16:02:33,805 - octoprint.access.users - INFO - Logged in user: MPCNC
2020-04-25 16:02:36,308 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-04-25 16:02:36,474 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-04-25 16:02:38,127 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-04-25 16:02:38,180 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-04-25 16:02:38,293 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 99.30ms
2020-04-25 16:05:02,456 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 108.67ms
2020-04-25 16:05:29,511 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 36.25ms
2020-04-25 16:05:35,605 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 83.96ms
2020-04-25 16:05:37,212 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:192.168.2.16) 53.24ms
Serial.log
2020-04-25 15:58:47,707 - Connecting to: /dev/ttyACM0
2020-04-25 15:58:47,721 - Changing monitoring state from "Offline" to "Opening serial port"
2020-04-25 15:58:47,736 - Connected to: Serial<id=0x71663f30, open=True>(port='/dev/ttyACM0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-04-25 15:58:47,737 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-04-25 15:58:47,767 - Send: N0 M110 N0*125
2020-04-25 15:58:48,898 - Recv: start
2020-04-25 15:58:48,903 - Recv: echo:Marlin 414 bugfix-2.0.x
2020-04-25 15:58:48,905 - Recv:
2020-04-25 15:58:48,907 - Recv: echo: Last Updated: 2019-10-18 | Author: (V1 Engineering, Ryan, 414)
2020-04-25 15:58:48,926 - Recv: echo:Compiled: Dec 18 2019
2020-04-25 15:58:48,930 - Recv: echo: Free Memory: 3474 PlannerBufferBytes: 1472
2020-04-25 15:58:48,977 - Send: N0 M110 N0*125
2020-04-25 15:58:56,536 - Recv: echo:SD init fail
2020-04-25 15:58:56,539 - Recv: echo:Hardcoded Default Settings Loaded
2020-04-25 15:58:56,541 - Recv: echo: G21 ; Units in mm (mm)
2020-04-25 15:58:56,543 - Recv: echo: M149 C ; Units in Celsius
2020-04-25 15:58:56,545 - Recv:
2020-04-25 15:58:56,547 - Recv: echo:Filament settings: Disabled
2020-04-25 15:58:56,549 - Recv: echo: M200 D3.00
2020-04-25 15:58:56,551 - Recv: echo: M200 D0
2020-04-25 15:58:56,553 - Recv: echo:Steps per unit:
2020-04-25 15:58:56,555 - Recv: echo: M92 X100.00 Y100.00 Z400.00 E100.00
2020-04-25 15:58:56,557 - Recv: echo:Maximum feedrates (units/s):
2020-04-25 15:58:56,559 - Recv: echo: M203 X120.00 Y120.00 Z30.00 E25.00
2020-04-25 15:58:56,561 - Recv: echo:Maximum Acceleration (units/s2):
2020-04-25 15:58:56,563 - Recv: echo: M201 X400.00 Y400.00 Z100.00 E2000.00
2020-04-25 15:58:56,565 - Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
2020-04-25 15:58:56,566 - Recv: echo: M204 P400.00 R3000.00 T400.00
2020-04-25 15:58:56,568 - Recv: echo:Advanced: B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> J<junc_dev>
2020-04-25 15:58:56,570 - Recv: echo: M205 B20000.00 S0.00 T0.00 J0.10
2020-04-25 15:58:56,573 - Recv: echo:Home offset:
2020-04-25 15:58:56,575 - Recv: echo: M206 X0.00 Y0.00 Z0.00
2020-04-25 15:58:56,576 - Recv: echo:Material heatup parameters:
2020-04-25 15:58:56,578 - Recv: echo: M145 S0 H196 B92 F0
2020-04-25 15:58:56,580 - Recv: echo: M145 S1 H240 B110 F0
2020-04-25 15:58:56,581 - Recv: echo:PID settings:
2020-04-25 15:58:56,583 - Recv: echo: M301 P17.98 I0.98 D83.62
2020-04-25 15:58:56,584 - Recv: echo:Stepper motor currents:
2020-04-25 15:58:56,587 - Recv: echo: M907 X900 Z900 E900
2020-04-25 15:58:56,820 - Recv: ok
2020-04-25 15:58:56,825 - Send: N0 M110 N0*125
2020-04-25 15:58:56,829 - Changing monitoring state from "Connecting" to "Operational"
2020-04-25 15:58:56,838 - Recv: echo:Unknown command: ""
2020-04-25 15:58:56,839 - Recv: ok
2020-04-25 15:58:56,844 - Send: N0 M110 N0*125
2020-04-25 15:58:56,855 - Recv: ok
2020-04-25 15:58:56,858 - Send: N1 M115*39
2020-04-25 15:58:56,871 - Recv: FIRMWARE_NAME:Marlin 414 bugfix-2.0.x (GitHub) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1 E CNC EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-04-25 15:58:56,878 - Recv: Cap:SERIAL_XON_XOFF:0
2020-04-25 15:58:56,882 - Recv: Cap:BINARY_FILE_TRANSFER:0
2020-04-25 15:58:56,884 - Recv: Cap:EEPROM:0
2020-04-25 15:58:56,887 - Recv: Cap:VOLUMETRIC:1
2020-04-25 15:58:56,891 - Recv: Cap:AUTOREPORT_TEMP:1
2020-04-25 15:58:56,895 - Recv: Cap:PROGRESS:0
2020-04-25 15:58:56,897 - Recv: Cap:PRINT_JOB:1
2020-04-25 15:58:56,900 - Recv: Cap:AUTOLEVEL:0
2020-04-25 15:58:56,902 - Recv: Cap:Z_PROBE:0
2020-04-25 15:58:56,904 - Recv: Cap:LEVELING_DATA:0
2020-04-25 15:58:56,906 - Recv: Cap:BUILD_PERCENT:0
2020-04-25 15:58:56,908 - Recv: Cap:SOFTWARE_POWER:0
2020-04-25 15:58:56,911 - Recv: Cap:TOGGLE_LIGHTS:0
2020-04-25 15:58:56,913 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2020-04-25 15:58:56,915 - Recv: Cap:EMERGENCY_PARSER:0
2020-04-25 15:58:56,917 - Recv: Cap:PROMPT_SUPPORT:0
2020-04-25 15:58:56,919 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2020-04-25 15:58:56,921 - Recv: Cap:THERMAL_PROTECTION:1
2020-04-25 15:58:56,923 - Recv: Cap:MOTION_MODES:1
2020-04-25 15:58:56,926 - Recv: Cap:CHAMBER_TEMPERATURE:0
2020-04-25 15:58:56,928 - Recv: ok
2020-04-25 15:58:56,930 - Send: M21
2020-04-25 15:58:59,344 - Recv: echo:SD init fail
2020-04-25 15:58:59,347 - Recv: ok
2020-04-25 15:58:59,349 - Send: M155 S2
2020-04-25 15:58:59,357 - Recv: ok
