Unable to use systemctl/service to start on CentOS
I am trying to install octoprint on a Virtualbox running on a QNAP NAS. The Virtualbox is running CentOS 8. I have successfully installed and run octoprint via this guide: Setting up OctoPrint on a Raspberry Pi running Raspbian
It works fine but not as a background service. I run it in a terminal window that closes the server once I close the terminal. I want to enable to system service via systemctl but this fails (see below).
I have added/edited the /etc/systemd/system/octoprint.service file according to my local environment:
[Unit]
Description=The snappy web interface for your 3D printer
After=network-online.target
Wants=network-online.target
[Service]
Type=simple
User=uncovery
ExecStart=/home/octoprint/venv/bin/octoprint serve
[Install]
WantedBy=multi-user.target
# systemctl enable octoprint
Failed to enable unit: Unit file octoprint.service does not exist.
# systemctl start octoprint
Failed to start octoprint.service: Unit octoprint.service not found.
I tried to follow this guide here: https://stackoverflow.com/questions/34501611/systemd-apparently-not-finding-service-file
Which leads me to:
# systemd-analyze verify octoprint.service
which returns nothing - so I assume it's correct?
Any idea what could be wrong here?
