I want to remove Octoprint from a Raspian install without just blowing the whole install away.
I've tried quite hard to find uninstall instructions for Octoprint online and largely failed.
I tried running a command I found : "pip uninstall OctoPrint" . But this just said Octoprint was not installed ( it is - I have a process running octoprint with the 'serve' command, and I can get to an Octoprint screen via localhost:5000 ).
I don't think logs are going to help
The system is an up to date Raspian Buster on an RPi 3.
