Logitech
I want to be able to unplug the webcam when I am not running the printer and plug it back in when I want to start using the printer without having to reboot the Docker container. However, the Docker container does not reattach to the camera because the camera is mounted to /dev/video1 instead of /dev/video0 when plugged back in. I suspect this is because Octoprint keeps video0 mounted when it is unplugged. How can I work around this? Or can it be fixed in the Octoprint program?
No logs exist for /var/log/webcamd.log and nothing about video in octoprint.log
Running OctoPrint 1.8.6 on Docker with the following compose file:
version: '3.7'
services:
octoprint:
image: octoprint/octoprint:latest
environment:
- ENABLE_MJPG_STREAMER=true
volumes:
- octoprint:/octoprint
- /dev:/dev
ports:
- 9090:80
device_cgroup_rules:
- "c 81:* rmw" # usb webcams
- "c 188:* rmw" # usb to serial converters
volumes:
octoprint:
