Unsupported Board type error Raspberry Pi 4 Model B
FYI, I've added a heads-up about this to the download page, should be live soon. Currently refers affected users to the 32bit nightlies.
It would be on the command line, accessed through SSH. It's not really necessary, it would just be nice info to know on our part.
I'm looking into a small minimally invasive adjustment to the image via CustoPiZer to see if we can solve this quickly for everyone currently affected and then do a proper release cycle for OctoPi without the added stress of this situation.
I would need someone with an affected RPi4 to flash an image I'll prepare and see if it boots. Would either of you be up for that @Skull or @ba33a?
edit Test image can be found at
Download the zip, unzip it, then flash with RPi imager. Would be good to know if it boots on a Pi that refuses to boot stock OctoPi 0.18.
Thanks a lot!!
My Pi version:
stock image didnt work for me, test image above did
As @Charlie_Powell suspected a new rev version for the Pi 4.
The new image with uploaded kernel and bootloader is now available in the Raspberry Pi Imager and via the download page.
I, too, am having no luck with installing Octopi. I have a new Pi 4 (4gb version). I can boot it up using the regular Pi OS (using the Raspberry Pi Imager) with no issues, whatsoever. ANY version of Octopi will not boot. At best, I get a flashing, black screen. I've tried using the Imager and doing it manually (file zip, etc.)...nightlies and the stable version. Octopi is the only reason I got the Pi, so it's a bit frustrating. Thanks for listening!
Do you get the 4 short 4 long flashes from the green LED on the board?
No. At first, it all seems normal - irregular green light action...so it looks like it's writing to the Pi. After a minute, or so, I just get a single, green flash (with red on the whole time) every once in a while.
That seems like it would be a different issue to this one with unsupported new hardware, which has a definitive error code. Those flashes seem to indicate the Pi is booting somewhat.
To be clear, did the stock OctoPi 0.18.0 image work for you with that Pi4?
For general reference, I have two Pi 4 boards (one purchased recently [mid-November?], one purchased at least a year ago) that the 0.18.0 image worked on without any issues:
Older Pi4 1GB:
Hardware        : BCM2711
Revision        : a03111
Serial          : 10000000e1ac49a0
Model           : Raspberry Pi 4 Model B Rev 1.1
Newer Pi4 2GB:
Hardware        : BCM2711
Revision        : b03114
Serial          : 10000000f2623af5
Model           : Raspberry Pi 4 Model B Rev 1.4
:thinking:
interesting
I agree. I guess it's possible that change from "b03114" to "c03114" is big enough to cause an issue (the letter code could be something more meaningful than a small incremental change). I might have access to another newer Pi4 - if that fails with 0.18.0, I'll post the cpuinfo and board label comparisons here, to hopefully start fleshing out some identification guidelines.
Raspberry Pi Documentation - Raspberry Pi Hardware has information about Pi revision codes in use; this actually made me realize (and confirm) that my older Pi4 is actually 1GB - I'll edit that for clarity.
I guess one revision had a drop in replacement and the other one needed software changes
The letter code is the RAM variant. The last two digits will indicate the hardware revision. In this case, the problem variant is the v1.5, so it would be a/b/c/d03115, for the 1/2/4/8GB Pi's respectively.
Last week, with advice from the RPi foundation, the OctoPi image was updated - the current 'Stable' that you can download has an updated kernel/bootloader so it should work with the newer hardware version.
So yes, I did have another Pi4 to check, and, lucky(?) me, it's one that does not work with the 0.18.0 image. With the same microSD card in these two pis, the one with the check mark on the ethernet jack and microSD card slot boots, but the one with the x mark on both does not boot (same behavior, four long then four short flashes of the green ACT LED).
I haven't gone through and overlaid the pictures to do a blink comparison, but the only major differences I noticed so far:
  • the extra "UK CA" text on the problematic board
  • there is a sticker with some form of 2D-barcode and numbers, which might be a date code, but I don't know how to interpret it
  • the main SoC date codes are different - assuming TAnnnn is a datecode, the "good" board has a SoC from week 33 (mid August) 2021, while the "bad" board is from week 38 (mid-late September) 2021
I will take some more pictures at some point, but to get started: https://photos.app.goo.gl/TXRHubmJFe385Toa8
I'll flash the nightly build and confirm it works, and get/share whatever information I can on the differences from cpuinfo etc., but that probably won't be until tomorrow.
@Charlie_Powell Alright, I'll use the latest stable version then - I thought this was still under investigation based on this discussion and an issue on OctoPi github (New RPi boards needing a newer image 路 Issue #761 路 guysoft/OctoPi 路 GitHub ) both only discussing a solution in the nightly builds, good to know it's resolved.
It's kind of been 'patched up' while we can work on the camera issues that have resulted from RPi OS moving from Debian buster to bullseye. A new image is still on the table - so if you want to do some testing, then please do go for it and report back in the thread you linked - any problems we can fix with the nightlies will be worth it for the next actual release, rather than the quick hotfix.
Alright, here's that troubled Pi, booted with the latest "stable" OctoPi (octopi-0.18.0-1.7.3-20220120112925.zip):
Hardware        : BCM2711
Revision        : b03115
Serial          : 100000006a5ceb9f
Model           : Raspberry Pi 4 Model B Rev 1.5
Booted without issue.
I've also just added an edit to my comment in the aforementioned issue to clarify this has indeed been resolved for now.
