**What is the problem?**i am unable to login to octopi using SSH, but can login using Octopod, or via browser and IP address
**What did you already try to solve it?**Double checked I am correctly entering username, ip address and then password when requested
Logs (octoprint.log, serial.log or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support!)says invalid username/password but copying and pasting from octopod login saved details
I think my problem is the username I chose. Andy@1. So when I try to login via (various) ssh portal programs the host name reads
Andy@1@192.168.0.123
I think the 2 β@β signs are causing the problem.
So my question is how do I change my username without being able to login via ssh?
I am not very experienced, as you can probably tell from my confused nomenclature. Hopefully this is easy
Thanks so much in advance
