I get an error trying to update OctoPrint. I have searched for a while on the forums without finding a similar error message (as far as I could understand them).
I tried a python script provided in a post to clean up logging, but I had no luck with it.
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.75 Safari/537.36 connectivity.connection_check: 1.1.1.1:53 connectivity.connection_ok: True connectivity.enabled: True connectivity.online: True env.hardware.cores: 4 env.hardware.freq: 1500.0 env.hardware.ram: 4041732096 env.os.bits: 32 env.os.id: linux env.os.platform: linux2 env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.1 env.plugins.pi_support.octopi_version: 0.17.0 env.plugins.pi_support.throttle_state: 0x0 env.python.pip: 19.3.1 env.python.version: 2.7.16 env.python.virtualenv: True octoprint.safe_mode: False octoprint.version: 1.6.1 systeminfo.generator: zipapiERROR MESSAGE
PS: I stripped down links as I am a new user.
Updating, please wait.
/home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/OctoPrint/OctoPrint/archive/1.7.3.zip --no-cache-dir
Looking in indexes: Simple index, piwheels - Simple index
Collecting githubcom/OctoPrint/OctoPrint/archive/1.7.3.zip
Downloading githubcom/OctoPrint/OctoPrint/archive/1.7.3.zip
Requirement already satisfied: OctoPrint-FileCheck>=2021.2.23 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (2021.2.23)
Collecting OctoPrint-FirmwareCheck>=2021.10.11
Downloading piwheelsorg/simple/octoprint-firmwarecheck/OctoPrint_FirmwareCheck-2021.10.11-py2.py3-none-any.whl
Requirement already satisfied: OctoPrint-PiSupport>=2021.10.28 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (2021.10.28)
Requirement already satisfied: markupsafe<2.0,>=1.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.1.1)
Requirement already satisfied: markdown<3.2,>=3.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (3.1.1)
Requirement already satisfied: wrapt<1.13,>=1.12.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.12.1)
Collecting flask<2,>=1.1.4
Downloading files.pythonhostedorg/packages/e8/6d/994208daa354f68fd89a34a8bafbeaab26fda84e7af1e35bdaed02b667e6/Flask-1.1.4-py2.py3-none-any.whl (94kB)
Collecting Jinja2<3,>=2.11.3
Downloading files.pythonhostedorg/packages/7e/c2/1eece8c95ddbc9b1aeb64f5783a9e07a286de42191b7204d67b7496ddf35/Jinja2-2.11.3-py2.py3-none-any.whl (125kB)
Requirement already satisfied: Flask-Login<0.6,>=0.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (0.5.0)
Requirement already satisfied: Flask-Babel<2,>=1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.0.0)
Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (2.0)
Requirement already satisfied: werkzeug<2,>=1.0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.0.1)
Requirement already satisfied: itsdangerous<2,>=1.1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.1.0)
Requirement already satisfied: cachelib<0.2,>=0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (0.1)
Collecting PyYAML<6,>=5.4.1
Downloading files.pythonhostedorg/packages/a0/a4/d63f2d7597e1a4b55aa3b4d6c5b029991d3b824b5bd331af8d4ab1ed687d/PyYAML-5.4.1.tar.gz (175kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'error'
ERROR: Command errored out with exit status 1:
command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-hr8GTz/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i Simple index --extra-index-url piwheels - Simple index -- setuptools wheel Cython
cwd: None
Complete output (24 lines):
File "/usr/lib/python2.7/runpy.py", line 174, in _run_module_as_main
"main", fname, loader, pkg_name)
File "/usr/lib/python2.7/runpy.py", line 72, in _run_code
exec code in run_globals
File "/home/pi/oprint/lib/python2.7/site-packages/pip/main.py", line 16, in
from pip._internal.main import main as _main # isort:skip # noqa
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/main.py", line 13, in
from pip._internal.cli.autocompletion import autocomplete
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/autocompletion.py", line 11, in
from pip._internal.cli.main_parser import create_main_parser
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/main_parser.py", line 7, in
from pip._internal.cli import cmdoptions
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/cmdoptions.py", line 25, in
from pip._internal.locations import USER_CACHE_DIR, get_src_prefix
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/locations.py", line 18, in
from pip._internal.utils import appdirs
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/appdirs.py", line 16, in
from pip._internal.utils.compat import WINDOWS, expanduser
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/compat.py", line 17, in
from pip._vendor.urllib3.util import IS_PYOPENSSL
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_vendor/urllib3/init.py", line 21, in
from logging import NullHandler
ImportError: cannot import name NullHandler
ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-hr8GTz/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i pypiorg/simple --extra-index-url piwheelsorg/simple -- setuptools wheel Cython Check the logs for full command output.
The update did not finish successfully. Please consult octoprint.log and plugin_softwareupdate_console.log for details.
