After the 1.9.0 update, The printer reaches set temperatures (hotend and bed), and then nothing prints. The temperatures are maintained. When cancelling a print,or otherwise, Octoprint won't accept a zero temperature. So when a job is cancelled, the hotend and bed remain at the previous temperature, or when manually setting the temperature to zero.
Safe mode didn't fix the problem, so it doesn't seem to be a rogue plugin.
On a second printer of the same model and settings, safemode did allow a job to be cancelled, but I didn't have the problem of a print failing to start, but i do have the "zero temperature" problem. A system reboot did not change the behaviour of the temperatures, and they remain at the previous set point.
OctoPrint version 1.9.0, OctoPi Version 0.18.0, running on Raspberry Pi 3 Model B Rev 1.2, printer Creality Ender3, firmware Marlin, browser firefox 113.0.2 (64-bit), operating system Windows 10
Looks like you might need to do a PID tune on your printer, the temperature is oscillating quite a lot as it comes up to target so the printer never accepts another command.
I think it's the cause of the problem you describe - if the temperature does not stabilise, the printer won't start. It also won't accept OctoPrint trying to cancel the print, which would explain why the temperature doesn't go back to zero.
The PID autotune seems to have solved this problem.
It doesn't explain why I the job cancelling on the 2nd printer as well, as that has a very stable temperature, and I can manually change that temperature.
Thanks for your help
