2021-12-17 03:05:04,218 /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/OctoPrint/OctoPrint/archive/1.7.2.zip --no-cache-dir
2021-12-17 03:05:07,432 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2021-12-17 03:05:07,435 > Collecting https://github.com/OctoPrint/OctoPrint/archive/1.7.2.zip
2021-12-17 03:05:08,440 > Downloading https://github.com/OctoPrint/OctoPrint/archive/1.7.2.zip (6.6 MB)
2021-12-17 03:05:23,693 > Requirement already satisfied: OctoPrint-FileCheck>=2021.2.23 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2021.2.23)
2021-12-17 03:05:23,694 > Collecting OctoPrint-FirmwareCheck>=2021.10.11
2021-12-17 03:05:23,695 > Downloading OctoPrint_FirmwareCheck-2021.10.11-py2.py3-none-any.whl (33 kB)
2021-12-17 03:05:23,695 > Requirement already satisfied: OctoPrint-PiSupport>=2021.10.28 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2021.10.28)
2021-12-17 03:05:23,695 > Requirement already satisfied: markupsafe<2.0,>=1.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.1.1)
2021-12-17 03:05:23,696 > Requirement already satisfied: markdown<3.2,>=3.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (3.1.1)
2021-12-17 03:05:23,700 > Requirement already satisfied: regex!=2018.11.6 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2018.2.21)
2021-12-17 03:05:23,700 > Requirement already satisfied: wrapt<1.13,>=1.12.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.12.1)
2021-12-17 03:05:23,701 > Collecting flask<2,>=1.1.4
2021-12-17 03:05:23,702 > Downloading Flask-1.1.4-py2.py3-none-any.whl (94 kB)
2021-12-17 03:05:24,706 > Collecting Jinja2<3,>=2.11.3
2021-12-17 03:05:24,708 > Downloading Jinja2-2.11.3-py2.py3-none-any.whl (125 kB)
2021-12-17 03:05:24,710 > Requirement already satisfied: Flask-Login<0.6,>=0.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (0.5.0)
2021-12-17 03:05:24,710 > Requirement already satisfied: Flask-Babel<2,>=1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.0.0)
2021-12-17 03:05:24,711 > Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2.0)
2021-12-17 03:05:24,712 > Requirement already satisfied: werkzeug<2,>=1.0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.0.1)
2021-12-17 03:05:24,712 > Requirement already satisfied: itsdangerous<2,>=1.1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.1.0)
2021-12-17 03:05:24,713 > Requirement already satisfied: cachelib<0.2,>=0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (0.1)
2021-12-17 03:05:26,131 > Collecting PyYAML<6,>=5.4.1
2021-12-17 03:05:26,133 > Downloading PyYAML-5.4.1.tar.gz (175 kB)
2021-12-17 03:05:27,301 > Installing build dependencies: started
2021-12-17 03:05:58,792 > Installing build dependencies: finished with status 'done'
2021-12-17 03:05:58,793 > Getting requirements to build wheel: started
2021-12-17 03:06:14,123 > Getting requirements to build wheel: finished with status 'done'
2021-12-17 03:06:14,123 > Preparing wheel metadata: started
2021-12-17 03:06:16,441 > Preparing wheel metadata: finished with status 'error'
2021-12-17 03:06:16,445 ! ERROR: Command errored out with exit status 1:
2021-12-17 03:06:16,446 ! command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /tmp/tmpLD40S6
2021-12-17 03:06:16,447 ! cwd: /tmp/pip-install-2KnhaG/pyyaml
2021-12-17 03:06:16,447 ! Complete output (2 lines):
2021-12-17 03:06:16,448 ! running dist_info
2021-12-17 03:06:16,448 ! error: 'egg_base' must be a directory name (got `/tmp/pip-modern-metadata-_YDIwG`)
2021-12-17 03:06:16,449 ! ----------------------------------------
2021-12-17 03:06:16,449 ! ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /tmp/tmpLD40S6 Check the logs for full command output.
disabling logging
yes
no
octoprint-systeminfo-20211217030805.zip (56.9 KB)
OctoPrint Version 1.6.1
OctoPi Version 0.15.1, running on Raspberry Pi 3 Model B Rev 1.2
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:95.0) Gecko/20100101 Firefox/95.0
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 917016576
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.15.1
env.python.pip: 20.3.4
env.python.version: 2.7.13
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
printer.firmware: Marlin 1.1.8 (Github)
