Octoprint fails to update to 1.3.11 from the frontend and from command line.
First time posting here, so I'm trying to get the formatting right. Bear with me!
ERROR: Complete output from command python setup.py egg_info:
ERROR: /usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'project_urls'
warnings.warn(msg)
/usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'long_description_content_type'
warnings.warn(msg)
File "<string>", line 1, in <module>
File "/tmp/pip-req-build-r9_NrW/setup.py", line 231, in <module>
setup(**params())
File "/usr/lib/python2.7/distutils/core.py", line 111, in setup
_setup_distribution = dist = klass(attrs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 266, in __init__
_Distribution.__init__(self,attrs)
File "/usr/lib/python2.7/distutils/dist.py", line 287, in __init__
self.finalize_options()
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 301, in finalize_options
ep.load()(self, ep.name, value)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2291, in load
return self.resolve()
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2301, in resolve
raise ImportError(str(exc))
ImportError: 'module' object has no attribute 'check_specifier'
ERROR: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-req-build-r9_NrW/
The update did not finish successfully. Please consult <code>octoprint.log</code> and <code>plugin_softwareupdate_console.log</code> for details.
Ran apt-get update/upgrade. Updated PIP. Disabled VPN & PiHole.
Logs (octoprint.log, serial.log or output on terminal tab, ...)
octoprint.log
UpdateError
2019-06-18 11:48:45,442 - octoprint.plugins.excluderegion - INFO - Event received: event=plugin_softwareupdate_update_failed payload={'to_version': '1.3.11', 'from_version': '1.3.10', 'target': 'octoprint'}
2019-06-18 12:00:10,001 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-06-18 12:02:27,843 - octoprint.plugins.softwareupdate - INFO - Starting update of octoprint to 1.3.11...
2019-06-18 12:02:46,565 - octoprint.plugins.softwareupdate - ERROR - Update of octoprint can not be performed, please also check plugin_softwareupdate_console.log for possible causes of this
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 969, in _perform_update
update_result = updater.perform_update(target, populated_check, target_version, log_cb=self._log, online=online)
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/updaters/pip.py", line 116, in perform_update
raise exceptions.UpdateError("Error while executing pip install", (stdout, stderr))
UpdateError
2019-06-18 12:02:46,569 - octoprint.plugins.excluderegion - INFO - Event received: event=plugin_softwareupdate_update_failed payload={'to_version': '1.3.11', 'from_version': '1.3.10', 'target': 'octoprint'}
2019-06-18 12:02:55,610 - octoprint.plugins.softwareupdate - INFO - Starting update of octoprint to 1.3.11...
2019-06-18 12:03:14,979 - octoprint.plugins.softwareupdate - ERROR - Update of octoprint can not be performed, please also check plugin_softwareupdate_console.log for possible causes of this
UpdateError
2019-06-18 12:03:14,989 - octoprint.plugins.excluderegion - INFO - Event received: event=plugin_softwareupdate_update_failed payload={'to_version': '1.3.11', 'from_version': '1.3.10', 'target': 'octoprint'}
2019-06-18 12:02:27,859 /home/pi/oprint/bin/python -m pip install https://github.com/foosel/OctoPrint/archive/1.3.11.zip --no-cache-dir
2019-06-18 12:02:32,405 ! DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7.
2019-06-18 12:02:33,225 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2019-06-18 12:02:33,279 > Collecting https://github.com/foosel/OctoPrint/archive/1.3.11.zip
2019-06-18 12:02:35,284 > Downloading https://github.com/foosel/OctoPrint/archive/1.3.11.zip (5.4MB)
2019-06-18 12:02:43,478 ! ERROR: Complete output from command python setup.py egg_info:
2019-06-18 12:02:43,479 ! ERROR: /usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'project_urls'
2019-06-18 12:02:43,543 ! warnings.warn(msg)
2019-06-18 12:02:43,544 ! /usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'long_description_content_type'
2019-06-18 12:02:43,545 ! warnings.warn(msg)
2019-06-18 12:02:43,546 ! Traceback (most recent call last):
2019-06-18 12:02:43,547 ! File "<string>", line 1, in <module>
2019-06-18 12:02:43,548 ! File "/tmp/pip-req-build-fmDDva/setup.py", line 231, in <module>
2019-06-18 12:02:43,549 ! setup(**params())
2019-06-18 12:02:43,549 ! File "/usr/lib/python2.7/distutils/core.py", line 111, in setup
2019-06-18 12:02:43,550 ! _setup_distribution = dist = klass(attrs)
2019-06-18 12:02:43,551 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 266, in __init__
2019-06-18 12:02:43,552 ! _Distribution.__init__(self,attrs)
2019-06-18 12:02:43,552 ! File "/usr/lib/python2.7/distutils/dist.py", line 287, in __init__
2019-06-18 12:02:43,553 ! self.finalize_options()
2019-06-18 12:02:43,554 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 301, in finalize_options
2019-06-18 12:02:43,555 ! ep.load()(self, ep.name, value)
2019-06-18 12:02:43,556 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2291, in load
2019-06-18 12:02:43,556 ! return self.resolve()
2019-06-18 12:02:43,557 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2301, in resolve
2019-06-18 12:02:43,558 ! raise ImportError(str(exc))
2019-06-18 12:02:43,559 ! ImportError: 'module' object has no attribute 'check_specifier'
2019-06-18 12:02:43,559 ! ----------------------------------------
2019-06-18 12:02:43,560 ! ERROR: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-req-build-fmDDva/
2019-06-18 12:02:55,624 /home/pi/oprint/bin/python -m pip install https://github.com/foosel/OctoPrint/archive/1.3.11.zip --no-cache-dir
2019-06-18 12:03:00,180 ! DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7.
2019-06-18 12:03:01,049 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2019-06-18 12:03:01,060 > Collecting https://github.com/foosel/OctoPrint/archive/1.3.11.zip
2019-06-18 12:03:02,072 > Downloading https://github.com/foosel/OctoPrint/archive/1.3.11.zip (5.4MB)
2019-06-18 12:03:10,587 ! ERROR: Complete output from command python setup.py egg_info:
2019-06-18 12:03:10,588 ! ERROR: /usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'project_urls'
2019-06-18 12:03:10,589 ! warnings.warn(msg)
2019-06-18 12:03:10,590 ! /usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'long_description_content_type'
2019-06-18 12:03:10,591 ! warnings.warn(msg)
2019-06-18 12:03:10,591 ! Traceback (most recent call last):
2019-06-18 12:03:10,592 ! File "<string>", line 1, in <module>
2019-06-18 12:03:10,593 ! File "/tmp/pip-req-build-r9_NrW/setup.py", line 231, in <module>
2019-06-18 12:03:10,593 ! setup(**params())
2019-06-18 12:03:10,594 ! File "/usr/lib/python2.7/distutils/core.py", line 111, in setup
2019-06-18 12:03:10,594 ! _setup_distribution = dist = klass(attrs)
2019-06-18 12:03:10,595 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 266, in __init__
2019-06-18 12:03:10,596 ! _Distribution.__init__(self,attrs)
2019-06-18 12:03:10,596 ! File "/usr/lib/python2.7/distutils/dist.py", line 287, in __init__
2019-06-18 12:03:10,597 ! self.finalize_options()
2019-06-18 12:03:10,597 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 301, in finalize_options
2019-06-18 12:03:10,598 ! ep.load()(self, ep.name, value)
2019-06-18 12:03:10,599 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2291, in load
2019-06-18 12:03:10,600 ! return self.resolve()
2019-06-18 12:03:10,601 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2301, in resolve
2019-06-18 12:03:10,601 ! raise ImportError(str(exc))
2019-06-18 12:03:10,602 ! ImportError: 'module' object has no attribute 'check_specifier'
2019-06-18 12:03:10,603 ! ----------------------------------------
2019-06-18 12:03:11,972 ! ERROR: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-req-build-r9_NrW/
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, ...)
OctoPrint version : 1.3.10
OctoPi version : 0.16.0
Running on Pi 3B+
Prusa Mk3S with MMU2S
