Hi, I'm trying to update OctoPrint plugins via cli, in webui I get a notification that there are plugins that need to be updated but pip command says that they are already updated, why?
Update Available
There are updates available for the following components:
DisplayLayerProgress Plugin: V1.23.3
OctoPod Plugin: 0.2.7
Print Time Genius Plugin
pip doesn't see any updated, why?
./oprint/bin/pip install -U OctoPrint-OctoPod
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already up-to-date: OctoPrint-OctoPod in ./oprint/lib/python3.7/site-packages (0.2.6)
./oprint/bin/octoprint plugins softwareupdate:update
Initializing settings & plugin subsystem...
Invalid syntax in /home/pi/oprint/lib/python3.7/site-packages/octoprint_detailedprogress/__init__.py for plugin detailedprogress
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/core.py", line 599, in _parse_metadata
root = ast.parse(f.read(), filename=path)
File "/usr/lib/python3.7/ast.py", line 35, in parse
return compile(source, filename, mode, PyCF_ONLY_AST)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_detailedprogress/__init__.py", line 45
currentData = { "progress": { "completion": 100, "printTimeLeft": 0 } }
TabError: inconsistent use of tabs and spaces in indentation
Invalid syntax in /home/pi/oprint/lib/python3.7/site-packages/octoprint_cost/__init__.py for plugin cost
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_cost/__init__.py", line 30
def get_template_configs(self):
Connected to server...
Update in progress, updating:
OctoPrint
GcodeEditor Plugin
Plabric
Cura Thumbnails
AstroPrint
Cancel object
Consolidate Temp Control
Dashboard Plugin
Filament Manager
File Check Plugin
Firmware Check Plugin
Firmware Updater
Fullscreen Plugin
OctoPod Plugin
PortLister
Preheat Button
PrusaSlicer Thumbnails
Simple Emergency Stop
STL Viewer
It stayed at this message for over an hour and nothing happened, it didn't continue or error out, just sat there... I was patient and left second time for two hours, again nothing happened.
Now that I go to webui I can see that all plugins have been updated. I was expecting some progress of plugins being updated in cli output, but it seams like they all have been updated but nothing was being reported in the cli. Is this normal behaviour ?
No, there should have been progress reports, but I think I know why there weren't. That uses the push socket, and I forgot to update the CLI to accommodate the stricter security on that since a couple versions. Shows you how little this feature gets used. Will look into fixing that for 1.5.0.
