I am trying to update OctoPi / OctoPrint because of the Python 2 eol notice. I am currently running OctoPi 0.17 so I am trying to use the update script. When I do, it tells me that it has failed due to a hash mismatch. Can someone tell me how to fix this without having to completely start fresh with a new SD image? I have already reverted back to the curent version for now until I hear back. Thanks.
$ python3 upgrade.py
OctoPrint Upgrade to Py 3 (v2.2.2)This script will move your existing OctoPrint configuration from Python 2 to Python 3
This script requires an internet connection and it will disrupt any ongoing print jobs.It will install the latest version of OctoPrint and all plugins.
No configuration or other files will be overwrittenPress [enter] to continue or ctrl-c to quit
Checking system info...
Detected OctoPi version 0.17.0
Found version: Python 2.7.16
Checking OctoPrint version...
OctoPrint version: 1.7.0
Reading installed plugins...
2022-01-23 00:01:34,556 - octolapse.init - INFO - Release mode detected.
Error in atexit._run_exitfuncs:
File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
func(*targs, **kargs)
File "/usr/lib/python2.7/logging/init.py", line 1676, in shutdown
h.close()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/logging/handlers.py", line 31, in close
self._executor.shutdown(wait=True)
AttributeError: 'OctolapseConsoleHandler' object has no attribute '_executor'
Error in sys.exitfunc:
h.close()
AttributeError: 'OctolapseConsoleHandler' object has no attribute '_executor'Plugins installed
- Tempsgraph Plugin
- Bed Visualizer
- Automatic Shutdown
- PrettyGCode
- M300 Player
- Simple Emergency Stop
- DeleteAfterPrint Plugin
- Themeify
- FileManager
- M117 Speech Synthesis
- EEPROM Marlin Editor Plugin
- PrintTimeGenius Plugin
- Octolapse
If there is an error above related to OctoLapse, please ignore, it makes no difference to operation![]()
- UI Customizer
If you think there is something missing from here, please check the list of plugins in OctoPrint
Press [enter] to continue or ctrl-c to quitUpdating package list...
Checking package list for python3-dev
Installing python3-dev...
Successfully installed python3-dev
Checking package list for python3-venv
Installing python3-venv...
Successfully installed python3-venv
Creating new Python 3 environment...
Successfully created Python 3 environment at /home/pi/oprint
Installing build dependencies...
Cache entry deserialization failed, entry ignored
Updating pip...
Cache entry deserialization failed, entry ignoredInstalling OctoPrint... (This may take a while - Do not cancel!)
Collecting required packages
ERROR: THESE PACKAGES DO NOT MATCH THE HASHES FROM THE REQUIREMENTS FILE. If you have updated the package versions, please update the hashes. Otherwise, examine the package contents carefully; someone may have tampered with them.
netaddr<0.9,>=0.8 from https://www.piwheels.org/simple/netaddr/netaddr-0.8.0-py3-none-any.whl#sha256=c3927d35504d7603e38b95ec164e53ce8baa46915681e4ccf2f277553c1fe284 (from OctoPrint):
Expected sha256 c3927d35504d7603e38b95ec164e53ce8baa46915681e4ccf2f277553c1fe284
Got a85a1d49d7df8f3ab464987c735e375bc024d50dcf7ef7fad63953a4cd8e40e5ERROR: OctoPrint failed to install
To restore your previous install, download the file at:
https://raw.githubusercontent.com/cp2004/Octoprint-Upgrade-To-Py3/master/go_back.pyCleaning up...
Error installing OctoPrint, cannot proceed
