Updating the OctoPrint from GUI to 1.4.1 failed. After reboot of the Raspberry, Octoprint GUI wont load.
"sudo service octoprint status" returns:
β octoprint.service - LSB: OctoPrint daemon
Loaded: loaded (/etc/init.d/octoprint; generated)
Active: active (exited) since Wed 2020-08-05 16:13:56 EEST; 1h 30min ago
Docs: man:systemd-sysv-generator(8)
Process: 1288 ExecStart=/etc/init.d/octoprint start (code=exited, status=0/SUCCESS)
Aug 05 16:13:56 usrpi4 systemd[1]: Starting LSB: OctoPrint daemon...
Aug 05 16:13:56 usrpi4 octoprint[1288]: * Starting OctoPrint Daemon OctoPrint
Aug 05 16:13:56 usrpi4 octoprint[1288]: ...done.
Aug 05 16:13:56 usrpi4 systemd[1]: Started LSB: OctoPrint daemon.
Tried to run manual update. It failed again.
I used the following commands:
~/OctoPrint/venv/bin/pip install -U octoprint
The result is in: Manual update - terminal.log
Complete Logs
octoprint.log (226.9 KB) plugin_pluginmanager_console.log (11.9 KB) plugin_softwareupdate_console.log (274.4 KB) serial.log (296 Bytes)
Manual update - terminal.log (17.7 KB)
Rasberry Pi 4B, 4GB
Ubuntu 20.04.1, x64
