So something weird happened while updating to 1.5.3. Instead of updating and restarting on it's own like it did on my other instances, this time it asked me to restart the instance except now the power icon was missing. So I unplugged the pi to force a reboot. When it rebooted, it said octoprint wasn't running and instructed me to ssh in and follow the instructions etc. nothing was running. sudo service octoprint start AND restart did nothing. Then it got weird. I looked for the logs but the OctoPrint directory was completely empty except for a README.txt file.
IDK WTH???
I'm totally lost on this one.
EDIT:I just tried a whereis command for Octoprint. there were no results.
I tried to update to octoprint 1.5.3
the ip address says octoprint not running, so I followed those ssh instructions
can't run at all
ummm
Complete Logs
they don't exist anymore. Infact the OctoPrint directory is completely empty except for a README.txt from version 1.3.x
Raspberry Pi 4B ethernet connection. That's literally it right now.
Did you look in ~/OctoPrint or did you look in ~/.octoprint? The latter is where you should be looking (and there never was a README.txt supposed to go in there.
What happens when you try to run OctoPrint manually?
power button is missing probably because the system commands got wiped out. Go into settings and look in the server section and set those and you'll get your power button back.
I wasn't there so I sadly can't possibly tell you. All signs point to something got corrupted though, so best run a file system check and maybe upgrade to a new SD card just in case. These things tend to die after some while.
My upgrade to 1.5.3 seemed to fail, but forcing the re-install this way helped me get back up and working. Thanks @jneilliii! Note that for it to work I needed to run all three commands recommended by @jneilliii:
This just saved mine - same scenario upgraded - enver came back up - nothing in logs beyond the upgrade - no response to python running or reboot - thought it was bricked - took a while but this got it going again! Thank you!
