Receive "Update failed! The update did not finish successfully. Please consult . . . logs for details", when trying to update to version 1.5.3
Repeated attempts to install, reviewed logs, but nothing helped.
Yes
Complete Logs
plugin_softwareupdate_console.log (280.8 KB)
serial.log (148 Bytes)
octoprint.log (132.6 KB)
Terminal.log (2.9 KB)
OctoPrint version 1.3.8, OctoPi version 0.15.1, printer Geeetech A10, Marlin 1.1.8, Board GT
2560 v3.0, browser MS Edge, operating system Win10 up-to-date
You could try to reinstall manually. SSH to your Pi and run these commands.
sudo apt update
sudo apt upgrade
~/oprint/bin/pip install --force-reinstall --no-cache-dir OctoPrint==1.5.3
Thanks for you rapid response for help! I was unable to try your fix until this morning. It worked!
I did have to add “service” after sudo” to your last line of code to complete the restart.
Thanks again for all your help!
See ya!
LD
¯_(ツ)_/¯
“Try to be as good as your dog thinks you are.”
Unknown
Thanks, I have updated the commands. Please make sure to Mark the Solution in case others find this in search.
Rodrigo
February 10, 2021, 5:22pm
#5
This did the trick for me now as well. Thanks!
For anyone else who might find this, I needed to do an intermediate update of pip for this solution to work for me. Thus, the following command sequence got it done:
sudo apt update
sudo apt upgrade -y
~/oprint/bin/pip install --upgrade pip
~/oprint/bin/pip install --force-reinstall --no-cache-dir OctoPrint==1.6.0
Good luck!
