I can not update from 1.6.1.
do that:
~/oprint/bin/pip install --force-reinstall --no-cache-dir OctoPrint==1.6.1
but with this error:
ERROR: Command errored out with exit status 1:
command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmp5QxY4Z
cwd: /tmp/pip-install-wMJRtY/pyyaml
Complete output (4 lines):
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 15, in <module>
from glob import glob
ImportError: No module named glob
ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmp5QxY4Z Check the logs for full command output.
I don't know how to do that.
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.1 Safari/605.1.15
connectivity.enabled: false
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 904245248
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.13.0
env.python.pip: 20.3.4
env.python.version: 2.7.9
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
OctoPi version: 1.6.1
, printer: ender3
, firmware: custom marlin
, browser:safari
, operating system: OS X
LOG
2021-11-04 20:02:54,613 /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/OctoPrint/OctoPrint/archive/1.7.2.zip --no-cache-dir
2021-11-04 20:02:57,656 > Collecting https://github.com/OctoPrint/OctoPrint/archive/1.7.2.zip
2021-11-04 20:02:58,659 > Downloading https://github.com/OctoPrint/OctoPrint/archive/1.7.2.zip (6.6 MB)
2021-11-04 20:03:07,258 > Requirement already satisfied: OctoPrint-FileCheck>=2021.2.23 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2021.2.23)
2021-11-04 20:03:07,259 > Collecting OctoPrint-FirmwareCheck>=2021.10.11
2021-11-04 20:03:07,259 > Downloading OctoPrint_FirmwareCheck-2021.10.11-py2.py3-none-any.whl (33 kB)
2021-11-04 20:03:07,260 > Requirement already satisfied: OctoPrint-PiSupport>=2021.10.28 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2021.10.28)
2021-11-04 20:03:07,260 > Requirement already satisfied: markupsafe<2.0,>=1.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.1.1)
2021-11-04 20:03:07,260 > Requirement already satisfied: markdown<3.2,>=3.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (3.1.1)
2021-11-04 20:03:07,261 > Requirement already satisfied: regex!=2018.11.6 in /home/pi/oprint/lib/python2.7/site-packages/regex-2016.04.15-py2.7-linux-armv7l.egg (from OctoPrint==1.7.2) (2016.4.15)
2021-11-04 20:03:07,263 > Requirement already satisfied: wrapt<1.13,>=1.12.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.12.1)
2021-11-04 20:03:07,264 > Collecting flask<2,>=1.1.4
2021-11-04 20:03:07,264 > Downloading Flask-1.1.4-py2.py3-none-any.whl (94 kB)
2021-11-04 20:03:07,265 > Collecting Jinja2<3,>=2.11.3
2021-11-04 20:03:07,265 > Downloading Jinja2-2.11.3-py2.py3-none-any.whl (125 kB)
2021-11-04 20:03:07,266 > Requirement already satisfied: Flask-Login<0.6,>=0.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (0.5.0)
2021-11-04 20:03:07,266 > Requirement already satisfied: Flask-Babel<2,>=1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.0.0)
2021-11-04 20:03:07,267 > Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2.0)
2021-11-04 20:03:07,267 > Requirement already satisfied: werkzeug<2,>=1.0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.0.1)
2021-11-04 20:03:07,268 > Requirement already satisfied: itsdangerous<2,>=1.1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.1.0)
2021-11-04 20:03:07,268 > Requirement already satisfied: cachelib<0.2,>=0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (0.1)
2021-11-04 20:03:08,273 > Collecting PyYAML<6,>=5.4.1
2021-11-04 20:03:08,273 > Downloading PyYAML-5.4.1.tar.gz (175 kB)
2021-11-04 20:03:09,276 > Installing build dependencies: started
2021-11-04 20:03:26,870 > Installing build dependencies: finished with status 'done'
2021-11-04 20:03:26,871 > Getting requirements to build wheel: started
2021-11-04 20:03:26,871 > Getting requirements to build wheel: finished with status 'error'
2021-11-04 20:03:26,874 ! ERROR: Command errored out with exit status 1:
2021-11-04 20:03:26,875 ! command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmp3Lrds2
2021-11-04 20:03:26,875 ! cwd: /tmp/pip-install-AKRLTf/pyyaml
2021-11-04 20:03:26,875 ! Complete output (4 lines):
2021-11-04 20:03:26,876 ! Traceback (most recent call last):
2021-11-04 20:03:26,876 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 15, in <module>
2021-11-04 20:03:26,879 ! from glob import glob
2021-11-04 20:03:26,879 ! ImportError: No module named glob
2021-11-04 20:03:26,880 ! ----------------------------------------
2021-11-04 20:03:26,880 ! ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmp3Lrds2 Check the logs for full command output.
