My octoprint will not update
I have tried freeing up space on my pc and re running the install
yes
no
It gives me an error every time I try to do this heres a copy
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 1903988736
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
ender 3 v2, octoprint version
these are the updates I am trying to complete
- Access Anywhere - The Spaghetti Detective: 1.7.2Release Notes
- Firmware Check Plugin: 2021.8.11Release Notes
- Pi Support Plugin: 2021.8.2Release Notes
When I do try to update it this is the error I get for each part
ERROR: Exception:
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/cli/base_command.py", line 224, in _main
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/cli/req_command.py", line 180, in wrapper
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/commands/install.py", line 280, in run
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/cache.py", line 293, in init
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/cache.py", line 262, in init
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/utils/temp_dir.py", line 141, in init
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/utils/temp_dir.py", line 189, in _create
File "/home/pi/oprint/lib/python3.7/tempfile.py", line 495, in mkdtemp
File "/home/pi/oprint/lib/python3.7/tempfile.py", line 265, in _sanitize_params
File "/home/pi/oprint/lib/python3.7/tempfile.py", line 433, in gettempdir
File "/home/pi/oprint/lib/python3.7/tempfile.py", line 368, in _get_default_tempdir
FileNotFoundError: [Errno 2] No usable temporary directory found in ['/tmp', '/var/tmp', '/usr/tmp', '/']
