the service apparently is not running as I get that page
I had just upgraded octoprint and octotext
rebooted with power
I removed all periprials, USB keyboard, the printer, the camera
(tried another board, but I think that board is bad.)
SSH - found that octoText kept on crashing in octoprint.log (see below)
tried to pip uninstall octotext but then pip crashed with a no space left error
so i went around and rm'd some mp4s and went back, pip still exceptions
then i got mad and rm'd octotext
confirmed it was dead with trying to pip uninstall it and it said not installed
rebooted via power
still complains service not running
Oh yeah - `ps -ef | grep -i octoprint | grep -i python does not seem to do anything, no error, just returns my command line. But just ps shows itself and bash running, no octoprint instance.
See below for what i saw on loging in via ssh - it seems to think that octoprint IS running!
ssh shows this on login:
Access OctoPrint from a web browser on your network by navigating to any of:
http://octopi.local
http://192.168.1.234
http://[2603:6011:2306:91ba:0:105f:c7eb:502f]
http://[2603:6011:2306:91ba:6e1e:ade1:7e06:f6ce]
https is also available, with a self-signed certificate.
This image comes without a desktop environment installed because it's not
required for running OctoPrint. If you want a desktop environment you can
install it via
sudo /home/pi/scripts/install-desktop
OctoPrint version : 1.8.0
OctoPi version    : 0.18.0
n/a
n/a
Well tell me how to get to it via SSH... i got some of octoprint.log ... it seemed to be happening every 500ms, that;s why i went to uninstall, then deleted it. OP isn't logging anything new now.
2022-05-19 02:27:53,462 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
|  hardware:
|    cores: 4
|    freq: 1500.0
|    ram: 1903988736
|  os:
|    bits: 32
|    platform: linux
|  plugins:
|    pi_support:
|      model: Raspberry Pi 4 Model B Rev 1.4
|      octopi_version: 0.18.0
|      throttle_state: '0x0'
|  python:
|    pip: 20.3.3
|    version: 3.7.3
|    virtualenv: /home/pi/oprint
2022-05-20 02:51:08,452 - octoprint.plugins.OctoText - ERROR - Exception while talking to your mail server [Errno -3] Temporary failure in name resolution
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_OctoText/init.py", line 258, in smtp_login_server
SMTP_server = smtplib.SMTP(name, port, timeout=5)
File "/usr/lib/python3.7/smtplib.py", line 251, in init
(code, msg) = self.connect(host, port)
File "/usr/lib/python3.7/smtplib.py", line 336, in connect
self.sock = self._get_socket(host, port, self.timeout)
File "/usr/lib/python3.7/smtplib.py", line 307, in _get_socket
self.source_address)
File "/usr/lib/python3.7/socket.py", line 707, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
2022-05-20 02:51:34,184 - octoprint.plugins.usb_keyboard - DEBUG - Found printer commands for key 'f4'. Sending '['M117 Normal Speed', 'M220 S100']'
2022-05-20 02:52:34,546 - octoprint.plugins.OctoText - ERROR - Exception while talking to your mail server [Errno -3] Temporary failure in name resolution
I just had upgraded to the new OctoPrint and also upgraded octotext - i fired off one print and sometime after finishing it died.
