Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3831)
twice today my Ender 5plus has randomly disconnected. Once about 15 minutes into a calibration cube and again a couple hours into a normal print.
swapped USB cable still failed
tried SD card worked fine
no
Complete Logs
My serial log said it had no info but here's the octoprint log
2020-12-07 01:28:46,421 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 01:28:46,425 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2020-12-07 01:28:46,425 - octoprint.server - INFO - OctoPrint 1.5.1
2020-12-07 01:28:46,430 - octoprint.plugin.core - INFO - 22 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| Consolidated Tabs (0.1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_consolidatedtabs
| Filament Sensor Reloaded (1.3.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filamentreload
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| Printoid Plugin (1.0.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_printoid
| SpoolManager Plugin (1.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_SpoolManager
| Themeify (1.2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2020-12-07 01:28:46,444 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 1979641856
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.1
| octopi_version: 0.17.0
| throttle_state: '0x0'
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-12-07 01:28:46,445 - octoprint.server - INFO - ------------------------------------------------------------------------------
2020-12-07 01:28:53,739 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {u'python': '2.7.16', u'os': u'linux', u'ram': 1979641856, u'octopi_version': u'0.17.0', u'version': u'1.5.1', u'plugins': u'consolidatedtabs:0.1.3,themeify:1.2.2,filamentreload:1.3.4,printoid:1.0.2,spoolmanager:1.2.0', u'pip': '19.3.1', u'cores': 4, u'freq': 1500.0, u'pi_model': u'Raspberry Pi 4 Model B Rev 1.1', u'bits': 32}
2020-12-07 01:28:54,317 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 86407}
2020-12-07 01:40:17,550 - octoprint.access.users - INFO - Cleaning up user session 19EED054AC59431E9516093CCCAA5463 for user Rancorbin
2020-12-07 01:40:17,551 - octoprint.access.users - INFO - Logged out user: Rancorbin
2020-12-07 01:40:17,552 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 01:40:17,554 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 01:40:17,737 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.29.181
2020-12-07 01:40:17,742 - octoprint.server.util.sockjs - INFO - User Rancorbin logged in on the socket from client ::ffff:192.168.29.181
2020-12-07 01:40:18,682 - tornado.access - WARNING - 404 GET /plugin/enclosure/updateUI (::ffff:192.168.29.181) 4.48ms
2020-12-07 01:40:18,695 - tornado.access - WARNING - 404 POST /api/plugin/psucontrol (::ffff:192.168.29.181) 20.15ms
2020-12-07 01:40:18,701 - tornado.access - WARNING - 404 POST /plugin/octolapse/loadState (::ffff:192.168.29.181) 14.48ms
2020-12-07 01:41:39,389 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 01:41:39,390 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 01:43:46,423 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 01:43:54,104 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 87307}
2020-12-07 01:45:42,153 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 01:45:42,154 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 01:48:10,991 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 01:48:10,992 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 01:48:14,830 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.29.181
2020-12-07 01:56:36,377 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 01:56:36,379 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 01:56:36,682 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.29.181
2020-12-07 01:56:36,699 - octoprint.server.util.sockjs - INFO - User Rancorbin logged in on the socket from client ::ffff:192.168.29.181
2020-12-07 01:56:38,124 - tornado.access - WARNING - 404 GET /plugin/enclosure/updateUI (::ffff:192.168.29.181) 4.04ms
2020-12-07 01:56:38,133 - tornado.access - WARNING - 404 POST /plugin/octolapse/loadState (::ffff:192.168.29.181) 15.32ms
2020-12-07 01:56:38,140 - tornado.access - WARNING - 404 POST /api/plugin/psucontrol (::ffff:192.168.29.181) 13.87ms
2020-12-07 01:58:46,424 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 01:58:54,231 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 88207}
2020-12-07 02:11:17,696 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 02:11:17,698 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 02:13:46,425 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 02:13:54,097 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 89107}
2020-12-07 02:28:46,426 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 02:28:54,051 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 90007}
2020-12-07 02:41:44,881 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 02:41:44,884 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 02:41:48,295 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.29.181
2020-12-07 02:43:46,428 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 02:43:54,256 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 90907}
2020-12-07 02:57:15,614 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 02:57:15,616 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 02:57:15,775 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.29.181
2020-12-07 02:57:15,788 - octoprint.server.util.sockjs - INFO - User Rancorbin logged in on the socket from client ::ffff:192.168.29.181
2020-12-07 02:57:16,756 - tornado.access - WARNING - 404 GET /plugin/enclosure/updateUI (::ffff:192.168.29.181) 4.93ms
2020-12-07 02:57:16,763 - tornado.access - WARNING - 404 POST /plugin/octolapse/loadState (::ffff:192.168.29.181) 15.91ms
2020-12-07 02:57:16,771 - tornado.access - WARNING - 404 POST /api/plugin/psucontrol (::ffff:192.168.29.181) 21.42ms
2020-12-07 02:57:24,978 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.29.181
2020-12-07 02:58:46,429 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 02:58:54,069 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 91807}
2020-12-07 03:13:46,430 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 03:13:53,961 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 92707}
2020-12-07 03:16:26,351 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 03:16:26,353 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 03:16:26,460 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.29.181
2020-12-07 03:16:26,464 - octoprint.server.util.sockjs - INFO - User Rancorbin logged in on the socket from client ::ffff:192.168.29.181
2020-12-07 03:16:27,410 - tornado.access - WARNING - 404 POST /api/plugin/psucontrol (::ffff:192.168.29.181) 7.40ms
2020-12-07 03:16:27,417 - tornado.access - WARNING - 404 GET /plugin/enclosure/updateUI (::ffff:192.168.29.181) 4.38ms
2020-12-07 03:16:27,426 - tornado.access - WARNING - 404 POST /plugin/octolapse/loadState (::ffff:192.168.29.181) 5.99ms
2020-12-07 03:16:41,426 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 03:16:41,428 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 03:16:49,118 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.29.181
2020-12-07 03:19:31,059 - octoprint.plugins.printoid - INFO - //// Send alert to Printoid: 'print-progress' with value 25 (Ender 5+)
2020-12-07 03:25:39,204 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 03:25:39,206 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 03:25:39,336 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.29.181
2020-12-07 03:25:39,342 - octoprint.server.util.sockjs - INFO - User Rancorbin logged in on the socket from client ::ffff:192.168.29.181
2020-12-07 03:25:40,331 - tornado.access - WARNING - 404 GET /plugin/enclosure/updateUI (::ffff:192.168.29.181) 4.08ms
2020-12-07 03:25:40,341 - tornado.access - WARNING - 404 POST /api/plugin/psucontrol (::ffff:192.168.29.181) 16.52ms
2020-12-07 03:25:40,347 - tornado.access - WARNING - 404 POST /plugin/octolapse/loadState (::ffff:192.168.29.181) 13.24ms
2020-12-07 03:26:50,172 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.29.181
2020-12-07 03:28:46,432 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 03:28:54,030 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 93607}
2020-12-07 03:30:19,718 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 03:30:19,720 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 03:30:20,028 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.29.181
2020-12-07 03:30:20,035 - octoprint.server.util.sockjs - INFO - User Rancorbin logged in on the socket from client ::ffff:192.168.29.181
2020-12-07 03:31:57,482 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.29.181
2020-12-07 03:36:46,140 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:36:50,632 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:39:40,031 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 03:39:40,033 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 03:39:40,272 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.29.181
2020-12-07 03:39:40,278 - octoprint.server.util.sockjs - INFO - User Rancorbin logged in on the socket from client ::ffff:192.168.29.181
2020-12-07 03:41:51,712 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.29.181
2020-12-07 03:42:52,512 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 03:42:52,513 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 03:42:52,780 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.29.181
2020-12-07 03:42:52,785 - octoprint.server.util.sockjs - INFO - User Rancorbin logged in on the socket from client ::ffff:192.168.29.181
2020-12-07 03:42:55,510 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 03:42:55,514 - octoprint.server.api - INFO - Actively logging in user Rancorbin from ::ffff:192.168.29.181
2020-12-07 03:43:46,433 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 03:43:54,317 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 94507}
2020-12-07 03:44:12,838 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.29.181
2020-12-07 03:44:22,628 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:44:22,780 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 3831, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 6455, in readline
c = self.read(1)
File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2020-12-07 03:44:22,784 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2020-12-07 03:44:22,800 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3831)"
2020-12-07 03:44:22,808 - octoprint.filemanager.analysis - INFO - Starting analysis of local:LEFT_SHIN_13.5h-187g-E5.gcode
2020-12-07 03:44:22,814 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/LEFT_SHIN_13.5h-187g-E5.gcode
2020-12-07 03:44:22,824 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-12-07 03:44:22,964 - octoprint.plugins.printoid - INFO - //// Send alert to Printoid: 'printer-state' with value Offline (Ender 5+)
2020-12-07 03:44:23,364 - octoprint.plugins.SpoolManager - WARNING - No spool selected, could not update values after print
2020-12-07 03:44:23,369 - octoprint.plugins.filamentreload - INFO - PrintFailed: Disabling filament sensor.
2020-12-07 03:44:23,949 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {u'origin': u'local', u'reason': u'error', u'commerror_text': u"SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3831", u'file': 'be4de4fffe0cc1647f62dc4c0d47a2a236551908', u'elapsed': 12483}
2020-12-07 03:44:27,243 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:45:56,276 - octoprint.filemanager.analysis - INFO - Analysis of entry local:LEFT_SHIN_13.5h-187g-E5.gcode finished, needed 93.47s
2020-12-07 03:55:02,564 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:55:03,582 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:55:03,833 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:55:04,169 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:55:04,628 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:55:04,910 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:55:05,194 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:55:10,306 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:55:13,067 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 03:58:31,853 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.29.141
2020-12-07 03:58:31,899 - octoprint.server.util.flask - INFO - Passively logging in user Rancorbin from ::ffff:192.168.29.141
2020-12-07 03:58:31,904 - octoprint.access.users - INFO - Logged in user: Rancorbin
2020-12-07 03:58:31,971 - octoprint.server.util.sockjs - INFO - User Rancorbin logged in on the socket from client ::ffff:192.168.29.141
2020-12-07 03:58:46,435 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 03:58:56,376 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 95407}
2020-12-07 04:04:26,656 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 04:07:40,584 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-12-07 04:09:26,414 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 04:11:11,942 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 04:11:16,097 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 04:11:16,606 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 04:11:20,275 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 04:11:21,197 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 04:11:37,206 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24
2020-12-07 04:11:49,241 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.29.181) 5.38ms
2020-12-07 04:13:46,436 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 04:13:54,102 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 96307}
2020-12-07 04:28:46,438 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-07 04:28:54,042 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 97207}
2020-12-07 04:29:56,070 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 24 >
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 1979641856
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.1
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.1
