I have updated pip which seems to have sorted the python error, but as you can see on the screen shot it still will not automatically update, also I have noticed there is a warning triangle on each plugin. When I scroll down the warning triangle is on every plugin. This is not stopping the Octoprint and the printer from working perfectly. I checked the Pi temperature over a 45min print and it reached 60.1 degrees, it would possibly go higher on a long print, so I am going to install a cooling fan.
Thank you for your ongoing help
Regards Troysie
Does it make a difference if you select 'advanced options' and then force-check? Or changing some of the release channels to try and see if that prompts it to refresh and update. Assuming you already tried restarting OctoPrint/rebooting etc.
This morning the option appeared to install 1.7.2. I installed this and after that everything else followed on and all updates installed. All is now working fine. Thank you for all your help.
Regards Troysie
Hello, had exactly the same problem, old python, unable to update octopi. Updated python, still couldn't update system.
The issue was resolved after that I increased the "minimum disk space", in software update -> plugin configuration.
Just reporting in case someone stumbles into this...
Still can't update Arc Welder but heh, will check into it when time allows...
Arc welder is a problem with the plugin's update configuration. There's a pre-release version you can install directly from GitHub, that fixes the issue but no stable release yet.
