I turned on my printer for the first time in 3.5 years and my OctoPrint 1.4.0 using an RPi 3 booted just fine. It's (obviously) just incredibly out of date. I tried updating through the update function in OctoPrint, and it was failing. I decided to make a backup, replace the board with a RPi 4 and started with a fresh image from the Raspberry Pi Imager (as suggested) and then tried to restore the 250MB backup I made and it keeps failing with the below errors:
Error while running restore
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/plugins/backup/__init__.py", line 1224, in _restore_backup
zip.extract(member, temp)
File "/usr/lib/python3.9/zipfile.py", line 1616, in extract
return self._extract_member(member, path, pwd)
File "/usr/lib/python3.9/zipfile.py", line 1688, in _extract_member
shutil.copyfileobj(source, target)
File "/usr/lib/python3.9/shutil.py", line 205, in copyfileobj
buf = fsrc_read(length)
File "/usr/lib/python3.9/zipfile.py", line 922, in read
data = self._read1(n)
File "/usr/lib/python3.9/zipfile.py", line 998, in _read1
data = self._decompressor.decompress(data, n)
zlib.error: Error -3 while decompressing data: invalid stored block lengths
Restore failed! Check the above output and octoprint.log for reasons as to why.
I have researched and it looks like someone in another thread suggested upgrading to 1.7 and creating a new backup and starting from there. I found instructions and used the following command:
~/oprint/bin/pip install --force-reinstall OctoPrint==1.7.0 --no-cache-dir
but after a little bit, I get the following error:
Collecting PyYAML<6,>=5.4.1
Downloading https://files.pythonhosted.org/packages/a0/a4/d63f2d7597e1a4b55aa3b4d6c5b029991d3b824b5bd331af8d4ab1ed687d/PyYAML-5.4.1.tar.gz (175kB)
|ββββββββββββββββββββββββββββββββ| 184kB 4.6MB/s
Installing build dependencies ... done
Getting requirements to build wheel ... error
ERROR: Command errored out with exit status 1:
command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpU8o786
cwd: /tmp/pip-install-SI6vXe/PyYAML
Complete output (46 lines):
running egg_info
creating lib/PyYAML.egg-info
writing lib/PyYAML.egg-info/PKG-INFO
writing top-level names to lib/PyYAML.egg-info/top_level.txt
writing dependency_links to lib/PyYAML.egg-info/dependency_links.txt
writing manifest file 'lib/PyYAML.egg-info/SOURCES.txt'
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 257, in <module>
main()
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 240, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 91, in get_requires_for_build_wheel
return hook(config_settings)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/build_meta.py", line 146, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=['wheel'])
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/build_meta.py", line 127, in _get_build_requires
self.run_setup()
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/build_meta.py", line 142, in run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 295, in <module>
python_requires='>=2.7, !=3.0.*, !=3.1.*, !=3.2.*, !=3.3.*, !=3.4.*, !=3.5.*',
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/__init__.py", line 145, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
dist.run_commands()
File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/egg_info.py", line 296, in run
self.find_sources()
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/egg_info.py", line 303, in find_sources
mm.run()
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/egg_info.py", line 534, in run
self.add_defaults()
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/egg_info.py", line 570, in add_defaults
sdist.add_defaults(self)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/py36compat.py", line 36, in add_defaults
self._add_defaults_ext()
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/py36compat.py", line 120, in _add_defaults_ext
self.filelist.extend(build_ext.get_source_files())
File "setup.py", line 201, in get_source_files
self.cython_sources(ext.sources, ext)
File "/usr/lib/python2.7/distutils/cmd.py", line 105, in __getattr__
raise AttributeError, attr
AttributeError: cython_sources
ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpU8o786 Check the logs for full command output.
WARNING: You are using pip version 19.3.1; however, version 20.3.4 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
n/a
I'm Sorry but it looks like this started in 1.6.0 and I'm trying to get there. ![]()
Working version:
Raspberry Pi 3B running Buster
Octoprint: 1.4.0
OctoPi: 0.17.0
Trying to install the image from Raspberry Pi Imager (1.9.3) on a Raspberry Pi 4 and then restore the backup from the above
