Well, this form looks friendly
After updating to 1.4.0 through the web interface, PrusaSlicer can no longer upload files to the Octoprint server - pops up error 403, as below:
I don't use an API key as I don't have my instance accessible through the net (don't have configuration access to shared router). Of course, I was previously able to upload files normally just by pressing "send G-code".
Googling the hell out of it. Most reports I can find are unrelated, saying they can't access the server interface at all (I can access everything just fine in browser - I can still upload files manually and print them). I haven't found a single other instance of this specific issue.
I also can't replicate in browser exactly what PrusaSlicer is doing. I can only tell from the logs that it's POSTing to /api/files/local, and when I browse to that URL, I get a JSON response of happiness. Also, if I "browse" in PrusaSlicer, it shows up, and if I "test", it reports success.
For some reason, "new users can only put 1 image in a post", so you're just gonna have to click these links instead:
upload://iL7KiavVuaeEAQuobs3nkJ4ynLU.png
upload://imjmWo3c4qpnrbwlbjIUyQJO7yE.png
edit: WELP THAT DOESN'T WORK EITHER
guess you're just gonna have to trust me.
Screenshot above. Confirmed by a line in the octoprint.log file:
2020-03-18 16:43:08,058 - tornado.access - WARNING - 403 POST /api/files/local (::ffff:192.168.86.26) 484.36ms
Nothing above or below it in this relevant time frame. Immediately before, I connected to the printer; immediately after, I uploaded the file manually. This is the only relevant log entry for when I encountered the screenshot above.
OctoPi on a Pi Zero, unmodified but apt-get updated a while ago, then updated through the UI when it popped up for 1.4.0 just a day ago.
OctoPrint version : 1.4.0
OctoPi version : 0.17.0
Previously had the Malyan connectivity fix plugin installed, but no longer needed after updating printer firmware to also give the necessary thermal runaway support (as prompted by the nag dialog to research & do the update), so I removed it. Running plugin-free now.
Monoprice Select Mini v2 cyborg mashup of countless repaired parts
PrusaSlicer 2.1.1 (201912101512) on Windows 10
so it's impossible to find...
