Updating to 1.7.3 isn't working
When I go to update OP (OctoPrint). it says it's updating, says successful, but it stays in the same version
I tried to run an update in the terminal using this code
pip install octoprint==1.7.3
I tried simply clicking the update button
Yes
I can't get the Systeminfo bundle, as my version doesn't support it.
I used an hp desktop running Ubuntu, I use an Ender 3 V2, and I used firefox to open the UI.
Did you activate your virtual environment before running this command?
What errors do you get when pressing 'update'? Instead of the systeminfo bundle, the octoprint.log and the plugin_softwareupdate_console.log files from OctoPrint's logging section would be useful.
octoprint.log (13.3 KB)
Tried with venv, no change. and I cant attach plugin_software_console.log files, it says its empty
Ok well here is your problem. You have installed OctoPrint using snap, which is not a supported method of installing it. We don't know who has published the octoprint-pfs snap distribution, but I know it has problems, especially with updating and connecting to printers. As you found out, it is also nearly 2 years outdated (with 1.4.0 not 1.7.x).
Uninstall the snap version of OctoPrint and then complete the setup guide on the forum, which should get you up and running with the latest version, working properly. Just substitute your username wherever pi is mentioned.
Is there a terminal command to delete op off of snap?
Presumably you can uninstall it the same way you installed it, through Snap.
How to uninstall snap ubuntu
