Thank you very much for your answer!
I want to avoid creating another SD.
I would like to keep the factory settings and accessories
Sorry but my octoprint does not have Systeminfo Bundle because it is outdated
this is the error message:
Actualizando, por favor espere.
Actualizando ahora OctoPrint a 1.7.2
/home/pi/oprint/bin/python "/home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4.post0.dev0_gfe481e1-py2.7.egg/octoprint/plugins/softwareupdate/scripts/update-octoprint.py" --branch= --force=false "/home/pi/OctoPrint" 1.7.2
From https://github.com/foosel/OctoPrint
d60c5a6..2885244 master -> origin/master
bcea483..43a62bf devel -> origin/devel
781c0d9..a3d077f maintenance -> origin/maintenance
945825f..2885244 rc/devel -> origin/rc/devel
945825f..2885244 rc/maintenance -> origin/rc/maintenance
444fe44..56e81d5 staging/bugfix -> origin/staging/bugfix
5ab4ab1..bb00b17 staging/devel -> origin/staging/devel
945825f..2885244 staging/maintenance -> origin/staging/maintenance
No local packages or download links found for markdown>=3.1,<3.2
File "setup.py", line 319, in <module>
setuptools.setup(**params())
File "/usr/lib/python2.7/distutils/core.py", line 111, in setup
_setup_distribution = dist = klass(attrs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 262, in __init__
self.fetch_build_eggs(attrs['setup_requires'])
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 287, in fetch_build_eggs
replace_conflicting=True,
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources.py", line 631, in resolve
dist = best[req.key] = env.best_match(req, ws, installer)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources.py", line 874, in best_match
return self.obtain(req, installer)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources.py", line 886, in obtain
return installer(requirement)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 338, in fetch_build_egg
return cmd.easy_install(req)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 630, in easy_install
raise DistutilsError(msg)
distutils.errors.DistutilsError: Could not find suitable distribution for Requirement.parse('markdown>=3.1,<3.2')
File "/home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4.post0.dev0_gfe481e1-py2.7.egg/octoprint/plugins/softwareupdate/scripts/update-octoprint.py", line 313, in <module>
main()
File "/home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4.post0.dev0_gfe481e1-py2.7.egg/octoprint/plugins/softwareupdate/scripts/update-octoprint.py", line 310, in main
install_source(python_executable, folder, user=args.user, sudo=args.sudo)
File "/home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.4.post0.dev0_gfe481e1-py2.7.egg/octoprint/plugins/softwareupdate/scripts/update-octoprint.py", line 254, in install_source
raise RuntimeError("Could not update, \"python setup.py install\" failed with returncode {}".format(returncode))
RuntimeError: Could not update, "python setup.py install" failed with returncode 1
