Hello, what to do? I cannot access octoprint via browser after updating from 1.8.2 to 1.8.3. How can I revert back or upgrade to 1.8.4?
~/.octoprint/logs/octoprint.log
2022-09-27 17:33:45,974 - octoprint.plugin.core - INFO - Plugin GCode Viewer is disabled.
2022-09-27 17:33:55,166 - octoprint.plugin.core - INFO - Plugin Anonymous Usage Tracking is disabled.
2022-09-27 17:34:01,402 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 16 mixin implementations, 38 hook handlers
2022-09-27 17:34:03,096 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2022-09-27 17:34:03,497 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/oprint/bin/octoprint", line 8, in <module>
sys.exit(main())
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/__init__.py", line 936, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1130, in __call__
return self.main(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/click/decorators.py", line 26, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/cli/server.py", line 330, in serve_command
disable_color=no_color,
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/cli/server.py", line 163, in run_server
octoprint_server.run()
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/__init__.py", line 371, in run
self._setup_app(app)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/__init__.py", line 1466, in _setup_app
from flask_limiter import Limiter
File "/home/pi/oprint/lib/python3.7/site-packages/flask_limiter/__init__.py", line 4, in <module>
from .errors import RateLimitExceeded
File "/home/pi/oprint/lib/python3.7/site-packages/flask_limiter/errors.py", line 7, in <module>
from .wrappers import Limit
File "/home/pi/oprint/lib/python3.7/site-packages/flask_limiter/wrappers.py", line 9, in <module>
from limits import RateLimitItem, parse_many
File "/home/pi/oprint/lib/python3.7/site-packages/limits/__init__.py", line 5, in <module>
from . import _version, aio, storage, strategies
File "/home/pi/oprint/lib/python3.7/site-packages/limits/aio/__init__.py", line 1, in <module>
from . import storage, strategies
File "/home/pi/oprint/lib/python3.7/site-packages/limits/aio/storage/__init__.py", line 6, in <module>
from .base import MovingWindowSupport, Storage
File "/home/pi/oprint/lib/python3.7/site-packages/limits/aio/storage/base.py", line 5, in <module>
from limits.storage.registry import StorageRegistry
File "/home/pi/oprint/lib/python3.7/site-packages/limits/storage/__init__.py", line 12, in <module>
File "/home/pi/oprint/lib/python3.7/site-packages/limits/storage/base.py", line 6, in <module>
from limits.util import LazyDependency
File "/home/pi/oprint/lib/python3.7/site-packages/limits/util.py", line 12, in <module>
from packaging.version import Version
ValueError: source code string cannot contain null bytes
2022-09-27 17:47:52,244 - octoprint.startup - INFO - ******************************************************************************
2022-09-27 17:47:52,261 - octoprint.startup - INFO - Starting OctoPrint 1.8.3
2022-09-27 17:47:52,262 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2022-09-27 17:47:52,263 - octoprint.startup - INFO - Reason for safe mode: problem during last startup
2022-09-27 17:47:52,264 - octoprint.startup - INFO - ******************************************************************************
2022-09-27 17:47:54,849 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2022-09-27 17:47:54,851 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2022-09-27 17:47:54,852 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2022-09-27 17:47:54,919 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and $
2022-09-27 17:48:02,136 - octoprint.plugin.core - INFO - Plugin GCode Viewer is disabled.
2022-09-27 17:48:03,580 - octoprint.plugin.core - INFO - Plugin Anonymous Usage Tracking is disabled.
2022-09-27 17:48:05,053 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 16 mixin implementations, 38 hook handlers
2022-09-27 17:48:05,304 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2022-09-27 17:48:05,463 - octoprint.cli.server - ERROR - Uncaught exception
sys.exit(main())
