@Charlie_Powell Sweet, nice and easy, looks good. Pi4, 0.12-0.15 (Can't remember where this started) original install with about 10 plugins and standard updates/upgrades since. Took less than 5 minutes to run and looks to be working fine. Thanks for the sweet script!
All went well with the base install, It initially screwed my GPX plugin. I couldn't install the plugin from the plugin manager so installed it manually. Re-created the gpx.ini file and away I went.
I'm running OctoPrint 1.4.2, OctoPi 0.18.0.
Thank you
Yeah, that bug of not being able to install should be fixed in the next release of OctoPrint.
If I were a newbie to Linux then I would have given up, So a message to anyone who is new and cannot follow logs and diagnose issues in Linux I would avoid the upgrade if you have tons of plugins.
But thank you to whoever created this script. I'm guessing @jneilliii?
Nope not me, @Charlie_Powell all the way. He's new on the scene and has quickly become a plugin author (WS281x LED Status) as well as a huge help in discord, here in the forum, and assisting Gina with issue/bug maintenance triage and fixing.
@Charlie_Powell Sorry, that is not correct. Klipper itself is written in Python. Look at this folder:
klippy is the core of Klipper's functionality. Klipper is still based on Python 2.7.There is even a branch of Klipper where work is being done on porting to Python 3, but it's stale. "Master" gets updates on a daily basis, the branch for Python 3 is three months old.
Octoklipper is simply a regular plugin for Octoprint, written by another guy.
It is not necessary for interoperability, but makes configuration of Klipper available through Octoprint which is pretty nice.
The plugin has a fork for Python 3 which seems to work pretty well.
Klipper itself seems quite stuck in 2.7. The maintainers are very active in developing functional improvements, but questions about Python 3 get canned answer. Since it's nothing I need to expose to the internet, that's sort of ok - as long as it stays compatible with my Octopi.
Ah ok, I read the wrong thing (maybe it was the printer firmware side? can't remember!), sorry.
I have done some more poking and it definitely creates its own virtual environment, looked through the install scripts - as good software does - so there should be no issue at all, since we are only touching OctoPrint's environment.
Klipper will still work, since all OctoPi distributions have both Python 2.7 and 3.x installed at a system level - that does not change in the script, the only thing that does is the virtual environment where OctoPrint (not klipper) is installed.
Hope that makes sense.
To add to that: while it is not possible to eg run OctoPrint with Python 3 and a plugin for OctoPrint with Python 2, it is possible to run OctoPrint with Python 3 and Klipper with Python 2 because they are different processes.
Isn't the plug-in for klipper required in order to use klipper?
From what I have heard, no, the plugin is not required. If you do intend to use the plugin with OctoPrint running on Python 3, you must use the Python 3 version of the plugin. However, Klipper itself can be running on Python 2.
Read (and follow) the instructions on upgrading more carefully. The upgrade script is not a plugin, so it should not be installed as a plugin. The upgrade script is something you would run in an SSH session (eg Putty), or using a keyboard and display on the Pi.
Is there a python 3 version of the klipper plugin? I can't find one.
@simpat1zq - there will be within the week, its being adopted by someone who has updated it to be Py3 compatible.
@jdcamc I'm not sure what to say.... This is not a plugin, read the instructions, it goes nowhere near the plugin manager.
You can use Octoprint and Klipper without the plugin. The printer-queue is /tmp/primter which looks a bit odd, but for Octoprint, Klipper behaves like a standard printer. It handles the common G-codes like temperature control, G28, G1 and the like. The plugin gives you the capability to edit the Klipper-configuration with data like default acceleration etc from within the browser. This is a huge bonus over Marlin where simple things like configuring ABL require the compilation of a new firmware file.
Thank you. Is there a github link to the project?
This is the link to the adoption ticket:
The repo is here:
The upgrade worked very well. So simple. Thanks for making the upgrade easy. I did have one issue after the upgrade. Trying to install a new plugin, I got the error message that my OctoPrint was not connected to the internet. I ran through all of the connectivity checks and it was connected. I spent a little time trying to identify the issue with no success. I rebooted Octoprint and the Raspberry Pi several times, no joy.
I decided to manually download the zip file for the plugin that I wanted. It upgraded and once the system rebooted it was working fine.
Thanks to all for making this so super simple.
Just need to wait for an update to Filament Manager
Not running it as root solved my issue.
