Upload Failed. Could not upload the file.
Drag and drop, Upload button, checked file type, looked in the logs although I don't understand it, searched youtube, and read other forums but nothing seemed similar to my issue.
Yes I tried.
I had the same exact issue in safe mode.
octoprint-systeminfo-20201202174006.zip (208.3 KB)
OctoPi 0.18.0 with OctoPrint 1.8.4 (build 20220927151125), Printer: Anycubic Vyper, Windows 10 OS, Raspberry Pi 4 Model B 2019 Quad Core 64 Bit WiFi Bluetooth (4GB), I use an ethernet cable directed to my pc that uses wifi to connect to the network (i was having issues locating my raspberry pi on my network so I went this route and it worked), octropi.local was not working so I use my IP address, I disable my VPN while using octoprint, I use chrome browser, Cura is my slicer version 5.1.1, the only thing I have done is do an extrusion calibration test. This is a fresh version of octoprint. I'm new at all of this so I do apologize if I've missed anything.
