Hi to all,
Whenever I try to upload a file (SD or local), get a small progress on the status bar and the upload freezes.
Several minutes later, I get a "Upload Failed" error.
If I create a folder (For example /test/), I can sometimes succeed to upload .. but not always !
I reinstalled Octoprint from scratch but still have the same issue ... Any ideas ?
Running version 1.3.8 on a Prusa MK3
Thanks !
What OS and browser are you using to upload? What is the filename? What do the octoprint.log logs say?
Windows 7 x64
Tried Chrome and IE
Filename can be about anything, I tried a lot of files.
When the upload fail, I seem to get nothing relevant in the logfile ...
Give me a sample filename. Or even upload a file so I can test it too.
Another thing to check is the javascript console.
Here is one example : calib-squares-30x30-2_PLA_OPTIMAL.gcode
It uploaded fine after few tries. But I only can upload successfully about 5% of the time
Don't see much in the Javascript console. Anything I should look for ?
Something weird is that the POST request stays "pending" in inspect console. My AdBlocker is disabled
