Hi all,
May I ask if I can upload a stl file from usb flash disk to octopi? How to realize automatic recognition and read of usb disk on octopi?
Thank you!
Hi all,
Thank you!
Well I think it would be possible with a gcode file, usbmount and watched folders.
But an stl has to be sliced first. So you would need to install the cura-engine plugin, slice the stl with the plugin and then you'll be able to print it.
You could do that with a script and maybe a plugin.
