New to 3D printing in 2021, new to RPI and Octoprint too.
So I have a weird behavior with the gcode file manager. When I upload to the RPI (not SD), my ArcWelder does its thing and then creates a new file. Both new files are greyed out at first. I tried the homing axes and it ungreys them if greyed out. The issue is when I tell it to load or load and print nothing changes in the GUI, file name doesn't show up STATE tab with either button. So if I delete the file and immediately reupload it automagically loads into the STATE TAB and is able to start printing.... Sometimes I have to reboot (not restart Octoprint) and then the trick works, never just works straight uploading and printing.
I've disabled and reenabled a bunch of mods and searched for it, found older tickets associated with some of the mods I had like gcode editor (which I uninstalled and no change), but nothing changes this behavior...
Yes
I think so
Complete Logs
Running current Octoprint version 1.5.3 Python 3.7.3 OctoPi 0.18.0 and all plugins are updated and current. Using Smith3D 2.0.x.17 5x5HS on Ender 3 V2 with 4.2.2 and BLTouch. Using Google Chrome (running the octopi local in incognito mode).
WRITE HEREoctoprint.log (2.1 MB)
