Hi all, I have a FlashForge Creator Pro and I have just setup Octoprint and installed the plugin GPX, its connected to the printer... but when I upload a .x3g file to the local drive or the SD card I get this error message:
Offline (Error: IOError: 'Command not supported or recognized' @ comm.py:_do_send_without_checksum:3
Thank you for your help in advance
Log...................
UnicodeEncodeError: 'ascii' codec can't encode character u'\ufffd' in position 11: ordinal not in range(128)
2020-07-02 19:41:01,487 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: See octoprint.log for details)"
2020-07-02 19:41:14,835 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.21
2020-07-02 19:43:13,795 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.19
2020-07-02 19:43:13,852 - octoprint.server.util.flask - INFO - Passively logging in user mark from ::ffff:192.168.2.19
2020-07-02 19:43:13,853 - octoprint.access.users - INFO - Logged in user: mark
2020-07-02 19:43:13,877 - octoprint.server.util.sockjs - INFO - User mark logged in on the socket from client ::ffff:192.168.2.19
2020-07-02 19:43:15,495 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.19
2020-07-02 19:43:15,738 - octoprint.server.util.flask - INFO - Passively logging in user mark from ::ffff:192.168.2.19
2020-07-02 19:43:15,739 - octoprint.access.users - INFO - Logged in user: mark
2020-07-02 19:43:17,063 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.19
2020-07-02 19:43:17,177 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.19
2020-07-02 19:43:17,388 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.19
2020-07-02 19:43:17,440 - octoprint.server.util.flask - INFO - Passively logging in user mark from ::ffff:192.168.2.19
2020-07-02 19:43:17,440 - octoprint.access.users - INFO - Logged in user: mark
2020-07-02 19:43:18,315 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-07-02 19:43:18,374 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-07-02 19:43:19,270 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-07-02 19:43:19,316 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-07-02 19:43:19,376 - octoprint.server.util.sockjs - INFO - User mark logged in on the socket from client ::ffff:192.168.2.19
2020-07-02 19:43:25,488 - octoprint.plugins.GPX - INFO - [a]
2020-07-02 19:43:25,491 - octoprint.plugins.GPX - INFO - [b]
2020-07-02 19:43:25,492 - octoprint.plugins.GPX - INFO - [left]
2020-07-02 19:43:25,495 - octoprint.plugins.GPX - INFO - [machine]
2020-07-02 19:43:25,496 - octoprint.plugins.GPX - INFO - [printer]
2020-07-02 19:43:25,498 - octoprint.plugins.GPX - INFO - build_progress=1
2020-07-02 19:43:25,499 - octoprint.plugins.GPX - INFO - ditto_printing=0
2020-07-02 19:43:25,500 - octoprint.plugins.GPX - INFO - gcode_flavor=makerbot
2020-07-02 19:43:25,500 - octoprint.plugins.GPX - INFO - machine_type=r1d
2020-07-02 19:43:25,501 - octoprint.plugins.GPX - INFO - recalculate_5d=0
2020-07-02 19:43:25,501 - octoprint.plugins.GPX - INFO - [right]
2020-07-02 19:43:25,504 - octoprint.plugins.GPX - INFO - [x]
2020-07-02 19:43:25,509 - octoprint.plugins.GPX - INFO - [y]
2020-07-02 19:43:25,510 - octoprint.plugins.GPX - INFO - [z]
2020-07-02 19:43:25,511 - octoprint.plugins.GPX - INFO - {'a': {}, 'None': {}, 'b': {}, 'machine': {}, 'printer': {'recalculate_5d': '0', 'gcode_flavor': 'makerbot', 'build_progress': '1', 'machine_type': 'r1d', 'ditto_printing': '0'}, 'right': {}, 'y': {}, 'x': {}, 'z': {}, 'left': {}}
2020-07-02 19:43:25,511 - octoprint.plugins.GPX - INFO - Connecting through x3g.
2020-07-02 19:43:25,514 - octoprint.plugins.GPX - INFO - GPXPrinter created, port: /dev/ttyACM0, baudrate: 115200
2020-07-02 19:43:28,649 - octoprint.plugins.GPX - INFO - [a]
2020-07-02 19:43:28,652 - octoprint.plugins.GPX - INFO - [b]
2020-07-02 19:43:28,657 - octoprint.plugins.GPX - INFO - [left]
2020-07-02 19:43:28,659 - octoprint.plugins.GPX - INFO - [machine]
2020-07-02 19:43:28,661 - octoprint.plugins.GPX - INFO - [printer]
2020-07-02 19:43:28,664 - octoprint.plugins.GPX - INFO - build_progress=1
2020-07-02 19:43:28,667 - octoprint.plugins.GPX - INFO - ditto_printing=0
2020-07-02 19:43:28,668 - octoprint.plugins.GPX - INFO - gcode_flavor=makerbot
2020-07-02 19:43:28,670 - octoprint.plugins.GPX - INFO - machine_type=r1d
2020-07-02 19:43:28,671 - octoprint.plugins.GPX - INFO - recalculate_5d=0
2020-07-02 19:43:28,671 - octoprint.plugins.GPX - INFO - [right]
2020-07-02 19:43:28,672 - octoprint.plugins.GPX - INFO - [x]
2020-07-02 19:43:28,676 - octoprint.plugins.GPX - INFO - [y]
2020-07-02 19:43:28,679 - octoprint.plugins.GPX - INFO - [z]
2020-07-02 19:43:28,680 - octoprint.plugins.GPX - INFO - {'a': {}, 'None': {}, 'b': {}, 'machine': {}, 'printer': {'recalculate_5d': '0', 'gcode_flavor': 'makerbot', 'build_progress': '1', 'machine_type': 'r1d', 'ditto_printing': '0'}, 'right': {}, 'y': {}, 'x': {}, 'z': {}, 'left': {}}
2020-07-02 19:43:28,680 - octoprint.plugins.GPX - INFO - Connecting through x3g.
2020-07-02 19:43:28,681 - octoprint.plugins.GPX - INFO - GPXPrinter created, port: /dev/ttyACM0, baudrate: 115200
2020-07-02 19:43:30,749 - octoprint.plugins.GPX - INFO - gpx.connect succeeded
2020-07-02 19:43:30,750 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2020-07-02 19:43:30,765 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-07-02 19:43:32,758 - octoprint.plugins.GPX - INFO - gpx.connect succeeded
2020-07-02 19:43:32,760 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2020-07-02 19:43:32,766 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-07-02 19:43:56,846 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.19
2020-07-02 19:43:56,870 - octoprint.server.util.flask - INFO - Passively logging in user mark from ::ffff:192.168.2.19
2020-07-02 19:43:56,871 - octoprint.access.users - INFO - Logged in user: mark
2020-07-02 19:43:57,284 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.19
2020-07-02 19:43:57,323 - octoprint.server.util.flask - INFO - Passively logging in user mark from ::ffff:192.168.2.19
2020-07-02 19:43:57,324 - octoprint.access.users - INFO - Logged in user: mark
2020-07-02 19:43:58,212 - octoprint.server.util.sockjs - INFO - User mark logged in on the socket from client ::ffff:192.168.2.19
2020-07-02 19:46:02,829 - octoprint.server.api.system - INFO - Performing command for core:reboot: sudo shutdown -r now
2020-07-02 19:46:03,174 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.19
2020-07-02 19:46:03,278 - octoprint.server - INFO - Shutting down...
2020-07-02 19:46:03,778 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2020-07-02 19:46:03,780 - octoprint.events - INFO - Event loop shut down
2020-07-02 19:46:04,213 - octoprint.server - INFO - Goodbye!
2020-07-02 19:46:09,820 - octoprint.startup - INFO - ******************************************************************************
2020-07-02 19:46:09,822 - octoprint.startup - INFO - Starting OctoPrint 1.4.0
2020-07-02 19:46:09,822 - octoprint.startup - INFO - ******************************************************************************
2020-07-02 19:46:10,206 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2020-07-02 19:46:10,258 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-07-02 19:46:11,263 - octoprint.plugin.core - INFO - Found 16 plugin(s) providing 16 mixin implementations, 32 hook handlers
2020-07-02 19:46:11,383 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-07-02 19:46:11,406 - octoprint.server - INFO - Intermediary server started
2020-07-02 19:46:11,407 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-07-02 19:46:11,470 - octoprint.plugin.core - INFO - Found 16 plugin(s) providing 16 mixin implementations, 32 hook handlers
2020-07-02 19:46:11,488 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-07-02 19:46:11,746 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-07-02 19:46:11,749 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-07-02 19:46:11,749 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-07-02 19:46:11,750 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-07-02 19:46:11,751 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-07-02 19:46:11,752 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-07-02 19:46:11,753 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-07-02 19:46:11,753 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-07-02 19:46:11,754 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-07-02 19:46:11,755 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-07-02 19:46:11,756 - octoprint.server - INFO - Added new permission from plugin printer_safety_check: PLUGIN_PRINTER_SAFETY_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_printer_safety_check_display')")
2020-07-02 19:46:11,757 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-07-02 19:46:11,757 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-07-02 19:46:11,797 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-07-02 19:46:12,467 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-02 19:46:13,018 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-07-02 19:46:13,020 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-07-02 19:46:13,020 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-07-02 19:46:13,024 - octoprint.plugin.core - INFO - Initialized 16 plugin implementation(s)
2020-07-02 19:46:13,031 - octoprint.plugin.core - INFO - 16 plugin(s) registered with the system:
| GPX (2.6.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GPX
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
2020-07-02 19:46:13,041 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 1979641856
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.1
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-07-02 19:46:13,048 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-07-02 19:46:13,063 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-07-02 19:46:13,542 - octoprint.server - INFO - Shutting down intermediary server...
2020-07-02 19:46:13,914 - octoprint.server - INFO - Intermediary server shut down
2020-07-02 19:46:13,915 - octoprint.events - INFO - Processing startup event, this is our first event
2020-07-02 19:46:13,917 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2020-07-02 19:46:13,918 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2020-07-02 19:46:13,918 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-07-02 19:46:13,959 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-07-02 19:46:13,967 - octoprint.server - INFO - Trying to connect to configured serial port None
2020-07-02 19:46:13,998 - octoprint.plugins.GPX - INFO - [a]
2020-07-02 19:46:13,999 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-07-02 19:46:14,000 - octoprint.plugins.GPX - INFO - [b]
2020-07-02 19:46:14,001 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-07-02 19:46:14,003 - octoprint.plugins.GPX - INFO - [left]
2020-07-02 19:46:14,007 - octoprint.plugins.GPX - INFO - [machine]
2020-07-02 19:46:14,009 - octoprint.plugins.GPX - INFO - [printer]
2020-07-02 19:46:14,009 - octoprint.plugins.GPX - INFO - build_progress=1
2020-07-02 19:46:14,010 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2020-07-02 19:46:14,010 - octoprint.plugins.GPX - INFO - ditto_printing=0
2020-07-02 19:46:14,014 - octoprint.plugins.GPX - INFO - gcode_flavor=makerbot
2020-07-02 19:46:14,015 - octoprint.plugins.GPX - INFO - machine_type=r1d
2020-07-02 19:46:14,016 - octoprint.plugins.GPX - INFO - recalculate_5d=0
2020-07-02 19:46:14,016 - octoprint.plugins.GPX - INFO - [right]
2020-07-02 19:46:14,017 - octoprint.plugins.GPX - INFO - [x]
2020-07-02 19:46:14,018 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2020-07-02 19:46:14,019 - octoprint.plugins.GPX - INFO - [y]
2020-07-02 19:46:14,020 - octoprint.plugins.GPX - INFO - [z]
2020-07-02 19:46:14,023 - octoprint.plugins.GPX - INFO - {'a': {}, 'None': {}, 'b': {}, 'machine': {}, 'printer': {'recalculate_5d': '0', 'gcode_flavor': 'makerbot', 'build_progress': '1', 'machine_type': 'r1d', 'ditto_printing': '0'}, 'right': {}, 'y': {}, 'x': {}, 'z': {}, 'left': {}}
2020-07-02 19:46:14,023 - octoprint.plugins.GPX - INFO - Connecting through x3g.
2020-07-02 19:46:14,037 - octoprint.plugins.GPX - INFO - GPXPrinter created, port: /dev/ttyACM0, baudrate: 115200
2020-07-02 19:46:16,066 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-07-02 19:46:16,179 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-07-02 19:46:16,799 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-02 19:46:16,851 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-07-02 19:46:17,023 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-07-02 19:46:17,146 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-07-02 19:46:17,736 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-02 19:46:17,737 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-02 19:46:18,065 - octoprint.plugins.GPX - INFO - gpx.connect succeeded
2020-07-02 19:46:18,067 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2020-07-02 19:46:18,070 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-07-02 19:46:19,103 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-02 19:46:19,135 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2020-07-02 19:46:19,141 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-02 19:46:19,949 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-07-02 19:46:19,950 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-07-02 19:46:19,962 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-07-02 19:46:20,025 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.2.38/'}
2020-07-02 19:46:21,200 - octoprint.util.comm - INFO - Printer reports firmware name "Sailfish"
2020-07-02 19:46:25,381 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.19
2020-07-02 19:46:26,163 - octoprint.server.util.flask - INFO - Passively logging in user mark from ::ffff:192.168.2.19
2020-07-02 19:46:26,164 - octoprint.access.users - INFO - Logged in user: mark
2020-07-02 19:46:26,215 - octoprint.server.util.sockjs - INFO - User mark logged in on the socket from client ::ffff:192.168.2.19
2020-07-02 19:46:29,713 - octoprint.server.preemptive_cache - INFO - ... done in 9.69s
2020-07-02 19:48:13,343 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-07-02 19:48:13,373 - octoprint.util.comm - ERROR - Unexpected error while writing to serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 3490, in _do_send_without_checksum
result = self._serial.write(to_send)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GPX/gpxprinter.py", line 138, in write
self._append(gpx.write(data))
IOError: Command not supported or recognized
2020-07-02 19:48:13,425 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Offline (Error: IOError: 'Command not supported or recognized' @ comm.py:_do_send_without_checksum:3490)"
2020-07-02 20:01:11,385 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-07-02 20:01:50,509 - octoprint.plugins.GPX - INFO - [a]
2020-07-02 20:01:50,510 - octoprint.plugins.GPX - INFO - [b]
2020-07-02 20:01:50,511 - octoprint.plugins.GPX - INFO - [left]
2020-07-02 20:01:50,512 - octoprint.plugins.GPX - INFO - [machine]
2020-07-02 20:01:50,512 - octoprint.plugins.GPX - INFO - [printer]
2020-07-02 20:01:50,513 - octoprint.plugins.GPX - INFO - build_progress=1
2020-07-02 20:01:50,514 - octoprint.plugins.GPX - INFO - ditto_printing=0
2020-07-02 20:01:50,514 - octoprint.plugins.GPX - INFO - gcode_flavor=makerbot
2020-07-02 20:01:50,515 - octoprint.plugins.GPX - INFO - machine_type=r1d
2020-07-02 20:01:50,515 - octoprint.plugins.GPX - INFO - recalculate_5d=0
2020-07-02 20:01:50,516 - octoprint.plugins.GPX - INFO - [right]
2020-07-02 20:01:50,517 - octoprint.plugins.GPX - INFO - [x]
2020-07-02 20:01:50,517 - octoprint.plugins.GPX - INFO - [y]
2020-07-02 20:01:50,518 - octoprint.plugins.GPX - INFO - [z]
2020-07-02 20:01:50,519 - octoprint.plugins.GPX - INFO - {'a': {}, 'None': {}, 'b': {}, 'machine': {}, 'printer': {'recalculate_5d': '0', 'gcode_flavor': 'makerbot', 'build_progress': '1', 'machine_type': 'r1d', 'ditto_printing': '0'}, 'right': {}, 'y': {}, 'x': {}, 'z': {}, 'left': {}}
2020-07-02 20:03:10,668 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.19
2020-07-02 20:03:10,764 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.19
2020-07-02 20:03:10,844 - octoprint.server.util.flask - INFO - Passively logging in user mark from ::ffff:192.168.2.19
2020-07-02 20:03:10,845 - octoprint.access.users - INFO - Logged in user: mark
2020-07-02 20:03:10,871 - octoprint.server.util.sockjs - INFO - User mark logged in on the socket from client ::ffff:192.168.2.19
2020-07-02 20:04:54,418 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.19
