Immediately after pressing the Connect button in octoprint, the target temperature of the bed is set to 7390. I am not sure if this is a Marlin 1.1.9 firmware issue or it is a OctoPrint issue... Could someone please kick me in the right direction?
Narrowed down that the issue is only related to pushing the Connect button in OctoPrint. It is not related to power cycling the Creality 3d CR10-s
Octoprint version: 1.3.10 running on Windows
Printer: Creality CR-10s
Firmware: Marlin 1.1.9
Output from Terminal tab:
Send: M21
Recv: echo:SD card ok
Recv: ok
Send: M20
Recv: Begin file list
Recv: End file list
Recv: ok
Send: M155 S2
Recv: echo:enqueueing "V?OD?P??\x01gW\x7fO?\x01?V?OE?\x1f_\x150???\x01"
Recv: echo:Unknown command: "V?OD?P??\x01gW\x7fO?\x01?V?OE?\x1f_\x150???\x01"
Recv: ok
Recv: T:118.34 /119.00 B:50.23 /7390.00 @:0 B@:127
Recv: T:117.68 /119.00 B:50.21 /7390.00 @:0 B@:127
Recv: T:116.87 /119.00 B:50.38 /7390.00 @:0 B@:127
Recv: T:115.92 /119.00 B:50.81 /7390.00 @:0 B@:127
Recv: T:114.95 /119.00 B:51.25 /7390.00 @:43 B@:127
Recv: T:113.79 /119.00 B:51.34 /7390.00 @:82 B@:127
Recv: T:113.01 /119.00 B:51.83 /7390.00 @:102 B@:127
Recv: T:112.53 /119.00 B:52.07 /7390.00 @:113 B@:127
Recv: T:112.58 /119.00 B:52.27 /7390.00 @:112 B@:127
