UPS Plugin - Does not see UPS until I save plugin config
When I start OctoPrint, the UPS plugin status is blank. journalctl shows the following error spamming once or twice per second:
octoprint[793]: 2024-09-20 11:31:45,697 - octoprint.plugins.ups - ERROR - An exception occurred while getting vars info
octoprint[793]: Traceback (most recent call last):
octoprint[793]: File "/home/schooner/OctoPrint/venv/lib/python3.11/site-packages/octoprint_ups/init.py", line 132, in _loop
octoprint[793]: vars = self.ups.list_vars(ups=self.config['ups'])
octoprint[793]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
octoprint[793]: File "/home/schooner/OctoPrint/venv/lib/python3.11/site-packages/nut2.py", line 157, in list_vars
octoprint[793]: self._srv_handler.write(b"LIST VAR %s\n" % ups.encode('utf-8'))
octoprint[793]: AttributeError: 'NoneType' object has no attribute 'encode'
I go into the plugin settings for UPS, click save. No config change required. This fixes the issue. Afterward I see this in the journal log:
octoprint.plugins.ups - INFO - Connection information changed.
Afterward the errors stop and the UPS icon in the status bar updates with correct info.
N/A
N/A\
Please let me know if this is needed and I will provide.
Latest Octoprint, latest RaspbianOS (64bit). All packages up to date.
Hopefully you've reported on the plugin's GitHub repo issue tracker already so @kantlivelong can be aware.
Seems like it's the same as this issue: https://github.com/kantlivelong/OctoPrint-UPS/issues/12 and should be fixed but not released yet maybe?
You could try installing the fixed version by copying/pasting this URL into Plugin Manager ? Get More > ...from URL and clicking install...
https://github.com/kantlivelong/OctoPrint-UPS/archive/refs/heads/devel.zip
Thank you @jneilliii , I will cross-post there. I did many googles on this but I didn't come across the articles you mentioned. I will give them a read.
Thanks again!
