Logitec C270
It was showing up using default octoprint settings, then after reboot, no longer
changed settings in /boot/octopi.txt , removed #, and added -y
Unfortunately no webcamd.log
Also no dmesg.log
LSUSB:
Bus 001 Device 011: ID 2412:2800
Bus 001 Device 014: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 001 Device 013: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
v4l2-ctl --list-formats:
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
[1]: 'MJPG' (Motion-JPEG, compressed)
octopi v17 with octoprint 1.3
I did do a lot of updates and installs of various components to get printerstats to work,following a page on this forum so not sure if that messed it up.uvcdynctrl-udev.log (2.4 MB) syslog1.log (76.7 KB) syslog.log (1.7 MB)
