Camera model SANDBERG USB Webcam 1080P HD
What is the problem? Camera worked for couple of hours then feed in Octoprint stopped. Would that be some network problem purchaps ?
What did you already try to solve it? flash the Pi 4 twice with no luck, change settings in octopi.txt, replace the camera with the new one, run all the system updates etc. reinstall Octoprint,
pi@octopi:~ $ sudo service webcamd status
β webcamd.service - the OctoPi webcam daemon with the user specified config
Active: active (running) since Sun 2021-02-21 20:14:20 GMT; 19h ago
Process: 981 ExecStart=/root/bin/webcamd (code=exited, status=0/SUCCESS)
Main PID: 1006 (mjpg_streamer)
Tasks: 378 (limit: 4915)
ββ1006 ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x48
Feb 21 20:14:20 octopi mjpg_streamer[1006]: MJPG-streamer [1006]: www-folder-path......: ./www-octopi/
Feb 21 20:14:20 octopi mjpg_streamer[1006]: MJPG-streamer [1006]: HTTP TCP port........: 8080
Feb 21 20:14:20 octopi mjpg_streamer[1006]: MJPG-streamer [1006]: HTTP Listen Address..: 127.0.0.1
Feb 21 20:14:20 octopi mjpg_streamer[1006]: MJPG-streamer [1006]: username:password....: disabled
Feb 21 20:14:20 octopi mjpg_streamer[1006]: MJPG-streamer [1006]: commands.............: disabled
Feb 21 20:14:20 octopi mjpg_streamer[1006]: MJPG-streamer [1006]: starting input plugin input_uvc.so
Feb 21 20:14:20 octopi mjpg_streamer[1006]: MJPG-streamer [1006]: starting output plugin: output_http.so (ID: 00)
Feb 21 20:14:20 octopi mjpg_streamer[1006]: MJPG-streamer [1006]: Can't enable video in first time
Feb 21 20:14:20 octopi mjpg_streamer[1006]: MJPG-streamer [1006]: cleaning up resources allocated by input thread
Feb 21 20:14:20 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
pi@octopi:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 1d6c:0103
Bus 001 Device 004: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
pi@octopi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.11-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1399 SMP Thu Jan 28 12:09:48 GMT 2021
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 999424
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 802816 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50636 r8192 d23092 u81920
[ 0.000000] pcpu-alloc: s50636 r8192 d23092 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 997120
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:800x480M@59 smsc95xx.macaddr=DC:A6:32:2B:DF:03 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=9a0ded57-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
[ 0.000000] Memory: 3602316K/3997696K available (10240K kernel code, 1354K rwdata, 3152K rodata, 2048K init, 890K bss, 133236K reserved, 262144K cma-reserved, 3211264K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 33824 entries in 67 pages
[ 0.000000] ftrace: allocated 67 pages with 3 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000101] bcm2835: system timer (irq = 25)
[ 0.000755] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000776] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000799] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000817] Switching to timer-based delay loop, resolution 18ns
[ 0.001070] Console: colour dummy device 80x30
[ 0.001816] printk: console [tty1] enabled
[ 0.001883] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001937] pid_max: default: 32768 minimum: 301
[ 0.002121] LSM: Security Framework initializing
[ 0.002319] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002364] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003941] Disabling memory control group subsystem
[ 0.004075] CPU: Testing write buffer coherency: ok
[ 0.004551] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005784] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005999] rcu: Hierarchical SRCU implementation.
[ 0.006946] smp: Bringing up secondary CPUs ...
[ 0.008184] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009561] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.011000] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.011159] smp: Brought up 1 node, 4 CPUs
[ 0.011206] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.011235] CPU: All CPU(s) started in HYP mode.
[ 0.011262] CPU: Virtualization extensions available.
[ 0.012104] devtmpfs: initialized
[ 0.026176] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026435] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026489] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.033227] pinctrl core: initialized pinctrl subsystem
[ 0.034328] NET: Registered protocol family 16
[ 0.038347] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.039141] audit: initializing netlink subsys (disabled)
[ 0.039417] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.040001] thermal_sys: Registered thermal governor 'step_wise'
[ 0.040704] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.040789] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.041198] Serial: AMBA PL011 UART driver
[ 0.074744] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.090899] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-01-27T22:19:57, variant start
[ 0.100912] raspberrypi-firmware soc:firmware: Firmware hash is 99d9a48302e4553cff3688692bb7e9ac760a03fa
[ 0.145949] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.150150] vgaarb: loaded
[ 0.150640] SCSI subsystem initialized
[ 0.150872] usbcore: registered new interface driver usbfs
[ 0.151353] usbcore: registered new interface driver hub
[ 0.151453] usbcore: registered new device driver usb
[ 0.151819] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.153748] clocksource: Switched to clocksource arch_sys_counter
[ 1.181494] VFS: Disk quotas dquot_6.6.0
[ 1.181622] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.181825] FS-Cache: Loaded
[ 1.182018] CacheFiles: Loaded
[ 1.183004] simple-framebuffer 3ea50000.framebuffer: framebuffer at 0x3ea50000, 0x177000 bytes, mapped to 0x(ptrval)
[ 1.183050] simple-framebuffer 3ea50000.framebuffer: format=a8r8g8b8, mode=800x480x32, linelength=3200
[ 1.185412] Console: switching to colour frame buffer device 100x30
[ 1.188434] simple-framebuffer 3ea50000.framebuffer: fb0: simplefb registered!
[ 1.198234] NET: Registered protocol family 2
[ 1.200219] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.201495] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.202692] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.203917] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.205200] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.206337] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.207682] NET: Registered protocol family 1
[ 1.209514] RPC: Registered named UNIX socket transport module.
[ 1.210624] RPC: Registered udp transport module.
[ 1.211712] RPC: Registered tcp transport module.
[ 1.212795] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.213944] PCI: CLS 0 bytes, default 64
[ 1.217951] Initialise system trusted keyrings
[ 1.219266] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.228759] zbud: loaded
[ 1.231771] FS-Cache: Netfs 'nfs' registered for caching
[ 1.233620] NFS: Registering the id_resolver key type
[ 1.234804] Key type id_resolver registered
[ 1.235874] Key type id_legacy registered
[ 1.237028] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.239092] Key type asymmetric registered
[ 1.240112] Asymmetric key parser 'x509' registered
[ 1.241293] bounce: pool size: 64 pages
[ 1.242314] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.243525] io scheduler mq-deadline registered
[ 1.244560] io scheduler kyber registered
[ 1.250075] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.251064] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.253004] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.254145] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.315855] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.317176] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.318142] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.319147] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.321201] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.322467] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.327064] PCI: bus0: Fast back to back transfers disabled
[ 1.328407] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.329539] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.330979] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.335493] PCI: bus1: Fast back to back transfers disabled
[ 1.336577] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.337629] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.338713] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.339733] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.341152] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.342394] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
[ 1.352100] iproc-rng200 fe104000.rng: hwrng registered
[ 1.353427] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.355384] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.369461] brd: module loaded
[ 1.382607] loop: module loaded
[ 1.385338] Loading iSCSI transport class v2.0-870.
[ 1.388771] libphy: Fixed MDIO Bus: probed
[ 1.391029] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.403863] libphy: bcmgenet MII bus: probed
[ 1.483902] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.486064] usbcore: registered new interface driver r8152
[ 1.487107] usbcore: registered new interface driver lan78xx
[ 1.488094] usbcore: registered new interface driver smsc95xx
[ 1.490628] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.491711] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.492641] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.496910] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
[ 1.500056] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.501056] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.502064] usb usb1: Product: xHCI Host Controller
[ 1.503059] usb usb1: Manufacturer: Linux 5.10.11-v7l+ xhci-hcd
[ 1.504091] usb usb1: SerialNumber: 0000:01:00.0
[ 1.505789] hub 1-0:1.0: USB hub found
[ 1.506849] hub 1-0:1.0: 1 port detected
[ 1.508451] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.509404] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.510351] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.511737] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.512703] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.513665] usb usb2: Product: xHCI Host Controller
[ 1.514650] usb usb2: Manufacturer: Linux 5.10.11-v7l+ xhci-hcd
[ 1.515609] usb usb2: SerialNumber: 0000:01:00.0
[ 1.517231] hub 2-0:1.0: USB hub found
[ 1.518233] hub 2-0:1.0: 4 ports detected
[ 1.520847] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.522098] dwc_otg: FIQ enabled
[ 1.522113] dwc_otg: NAK holdoff enabled
[ 1.522127] dwc_otg: FIQ split-transaction FSM enabled
[ 1.522158] Module dwc_common_port init
[ 1.522600] usbcore: registered new interface driver uas
[ 1.523655] usbcore: registered new interface driver usb-storage
[ 1.524802] mousedev: PS/2 mouse device common for all mice
[ 1.527415] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.531888] sdhci: Secure Digital Host Controller Interface driver
[ 1.532857] sdhci: Copyright(c) Pierre Ossman
[ 1.534521] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.536057] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.539858] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.541114] hid: raw HID events driver (C) Jiri Kosina
[ 1.542211] usbcore: registered new interface driver usbhid
[ 1.543139] usbhid: USB HID core driver
[ 1.549896] Initializing XFRM netlink socket
[ 1.550882] NET: Registered protocol family 17
[ 1.551930] Key type dns_resolver registered
[ 1.553216] Registering SWP/SWPB emulation handler
[ 1.554439] registered taskstats version 1
[ 1.555347] Loading compiled-in X.509 certificates
[ 1.557022] Key type ._fscrypt registered
[ 1.557900] Key type .fscrypt registered
[ 1.558752] Key type fscrypt-provisioning registered
[ 1.570988] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.572201] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.573171] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.580848] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.582873] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.583914] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.614012] of_cfs_init
[ 1.615232] of_cfs_init: OK
[ 1.630313] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.632914] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.635478] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.639294] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.641758] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.649519] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.651350] Waiting for root device PARTUUID=9a0ded57-02...
[ 1.683193] random: fast init done
[ 1.709607] mmc1: new high speed SDIO card at address 0001
[ 1.753355] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[ 1.755157] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[ 1.759828] mmcblk0: p1 p2
[ 1.793808] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.794720] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.873797] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.056429] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.057422] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.058358] usb 1-1: Product: USB2.0 Hub
[ 2.061388] hub 1-1:1.0: USB hub found
[ 2.062490] hub 1-1:1.0: 4 ports detected
[ 2.063016] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 2.066306] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[ 2.067158] EXT4-fs (mmcblk0p2): recovery complete
[ 2.085133] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.086100] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.094110] devtmpfs: mounted
[ 2.103987] Freeing unused kernel memory: 2048K
[ 2.105219] Run /sbin/init as init process
[ 2.106161] with arguments:
[ 2.106176] /sbin/init
[ 2.106190] with environment:
[ 2.106205] HOME=/
[ 2.106219] TERM=linux
[ 2.383806] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
[ 2.515809] usb 1-1.1: not running at top speed; connect to a high speed hub
[ 2.519111] systemd[1]: System time before build time, advancing clock.
[ 2.527321] usb 1-1.1: New USB device found, idVendor=1d6c, idProduct=0103, bcdDevice= 0.10
[ 2.528363] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.529380] usb 1-1.1: Product: webcam
[ 2.530372] usb 1-1.1: Manufacturer: webcam
[ 2.612667] NET: Registered protocol family 10
[ 2.615091] Segment Routing with IPv6
[ 2.633801] usb 1-1.2: new full-speed USB device number 4 using xhci_hcd
[ 2.682162] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.686692] systemd[1]: Detected architecture arm.
[ 2.778941] systemd[1]: Set hostname to <octopi>.
[ 2.779983] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 2.779999] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.782207] usb 1-1.2: Product: USB Serial
[ 3.508776] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.522778] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.525066] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.527940] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.529357] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.534150] systemd[1]: Created slice User and Session Slice.
[ 3.537680] systemd[1]: Listening on Journal Audit Socket.
[ 3.540735] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.546130] systemd[1]: Created slice system-getty.slice.
[ 3.549478] systemd[1]: Listening on Syslog Socket.
[ 4.247600] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.355649] systemd-journald[111]: Received request to flush runtime journal from PID 1
[ 4.947595] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.952738] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.953351] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.954087] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.999983] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.002319] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.002345] [vc_sm_connected_init]: start
[ 5.030548] mc: Linux media interface: v0.10
[ 5.034113] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.036066] [vc_sm_connected_init]: installed successfully
[ 5.039840] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.043011] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.059832] videodev: Linux video capture interface: v2.00
[ 5.114654] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.129732] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.151811] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.170094] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.175189] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.175236] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.188106] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.188175] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.209640] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.210097] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.210141] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.210290] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.213659] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.217559] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.217633] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.217701] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.217809] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.217875] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.218483] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.657701] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.675692] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.676486] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.676511] checking generic (3ea50000 177000) vs hw (0 ffffffffffffffff)
[ 5.676527] fb0: switching to vc4drmfb from simple
[ 5.677114] Console: switching to colour dummy device 80x30
[ 5.682645] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.703721] Console: switching to colour frame buffer device 100x30
[ 5.716668] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 5.720280] usbcore: registered new interface driver usbserial_generic
[ 5.720396] usbserial: USB Serial support registered for generic
[ 5.727564] usbcore: registered new interface driver ch341
[ 5.728217] usbserial: USB Serial support registered for ch341-uart
[ 5.728360] ch341 1-1.2:1.0: ch341-uart converter detected
[ 5.733335] cdc_acm 1-1.1:1.4: ttyACM0: USB ACM device
[ 5.739301] usbcore: registered new interface driver cdc_acm
[ 5.739319] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5.750355] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
[ 5.770476] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.941859] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.958098] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.958979] usbcore: registered new interface driver brcmfmac
[ 5.982508] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 6.016919] uvcvideo: Found UVC 1.00 device webcam (1d6c:0103)
[ 6.017062] usbcore: registered new interface driver snd-usb-audio
[ 6.042165] input: webcam as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input0
[ 6.045826] usbcore: registered new interface driver uvcvideo
[ 6.045871] USB Video Class driver (1.1.1)
[ 6.178068] ads7846 spi0.1: supply vcc not found, using dummy regulator
[ 6.178763] ads7846 spi0.1: touchscreen, irq 65
[ 6.194376] input: ADS7846 Touchscreen as /devices/platform/soc/fe204000.spi/spi_master/spi0/spi0.1/input/input1
[ 6.244621] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.260397] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 8.026633] uart-pl011 fe201000.serial: no DMA platform data
[ 8.082146] random: crng init done
[ 8.082176] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.258047] 8021q: 802.1Q VLAN Support v1.8
[ 8.493937] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.682541] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.006731] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 9.007233] bcmgenet fd580000.ethernet eth0: Link is Down
[ 14.196603] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 14.901929] Bluetooth: Core ver 2.22
[ 14.902036] NET: Registered protocol family 31
[ 14.902053] Bluetooth: HCI device and connection manager initialized
[ 14.902083] Bluetooth: HCI socket layer initialized
[ 14.902107] Bluetooth: L2CAP socket layer initialized
[ 14.902141] Bluetooth: SCO socket layer initialized
[ 14.913141] Bluetooth: HCI UART driver ver 2.3
[ 14.913163] Bluetooth: HCI UART protocol H4 registered
[ 14.913272] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.913590] Bluetooth: HCI UART protocol Broadcom registered
[ 15.070880] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.070890] Bluetooth: BNEP filters: protocol multicast
[ 15.070904] Bluetooth: BNEP socket layer initialized
[ 21.729289] broken atomic modeset userspace detected, disabling atomic
[50074.580379] broken atomic modeset userspace detected, disabling atomic
[50125.812318] broken atomic modeset userspace detected, disabling atomic
[51187.970388] v3d fec00000.v3d: MMU error from client L2T (0) at 0xa61000, pte invalid
[51723.075921] broken atomic modeset userspace detected, disabling atomic
[52086.339568] broken atomic modeset userspace detected, disabling atomic
[53175.615640] broken atomic modeset userspace detected, disabling atomic
[53778.872070] broken atomic modeset userspace detected, disabling atomic
[53900.117541] broken atomic modeset userspace detected, disabling atomic
[55345.383347] broken atomic modeset userspace detected, disabling atomic
[58084.659485] broken atomic modeset userspace detected, disabling atomic
[60407.937966] broken atomic modeset userspace detected, disabling atomic
[60619.089172] usb 1-1.1: USB disconnect, device number 3
[60623.223995] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
[60623.355431] usb 1-1.4: config 1 interface 4 altsetting 0 endpoint 0x82 has an invalid bInterval 255, changing to 11
[60623.355454] usb 1-1.4: config 1 interface 5 altsetting 0 bulk endpoint 0x84 has invalid maxpacket 64
[60623.355473] usb 1-1.4: config 1 interface 5 altsetting 0 bulk endpoint 0x4 has invalid maxpacket 64
[60623.356259] usb 1-1.4: New USB device found, idVendor=1d6c, idProduct=0103, bcdDevice= 0.10
[60623.356277] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[60623.356292] usb 1-1.4: Product: webcam
[60623.356307] usb 1-1.4: Manufacturer: webcam
[60623.359714] uvcvideo: Found UVC 1.00 device webcam (1d6c:0103)
[60623.363198] input: webcam as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input2
[60623.370696] cdc_acm 1-1.4:1.4: ttyACM0: USB ACM device
[61609.222396] broken atomic modeset userspace detected, disabling atomic
[62210.479971] broken atomic modeset userspace detected, disabling atomic
[62689.741873] broken atomic modeset userspace detected, disabling atomic
[64250.993918] broken atomic modeset userspace detected, disabling atomic
[64481.010960] broken atomic modeset userspace detected, disabling atomic
[66044.286817] broken atomic modeset userspace detected, disabling atomic
[66167.543415] broken atomic modeset userspace detected, disabling atomic
Additional information about your setup (OctoPrint version, OctoPi version, ...) Version 1.5.3, Raspberry Pi 4, original power supply.
