USB Camera Has massive lag and little to no FPS
Hello, I have NexiGo N60 USB Computer Camera hooked up to my raspberry pi 3B+. If I put the resolution anything about 480p the camera feed updates once in like a few minutes. I know this is a 1080 camera and I currently have it at 480p and 20 fps but it still barely updates the feed. I don't think it is working properly.
Tried different resolutions and fps but it only really updates feed on the lowest resolution
YES
NO
octoprint-systeminfo-20211111210047.zip (1.7 MB)
Ender 3 Pro
Version 1.7.0
Version 0.18.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Marlin V1.3.1
anything helps!
There are issues with the ABL expert and TheSpaghettyDedective.
Please try again in safe mode and share a new systeminfo bundle with that run.
And please don't power cycle the Pi. Sooner or later you will have a corrupted file structure on the SD card.
If you are using TSD premium, note that it will override the usual streaming settings.
